Search results for: 'robota plus'
- robots plus
- robota plcs
- plus 125
- plus one contact number 20
- robota plcs 124
- robota plc 124
CODESYS Virtual Safe Control SL 000139Safety without compromise: With CODESYS Virtual Safe Control SL, you get a certified SIL3 controller without any special hardware requirements. Install it on your commercial-of-the-shelf hardware and experience maximum safety - only with CODESYS.
CODESYS Sensor App for Android 000073$0.00With the product “CODESYS Sensor App for Android”, the sensor data of from an Android smartphone can be sent to a CODESYS controller.
HVAC Modbus SL 2312000013$0.00HVAC Modbus Library. Send and receive Modbus data points via RTU (serial) or TCP. Finished function blocks many manufacturers and devices from building automation. Further description: https://support.powerio.com/codesys-hvac/hvac-modbus-library/description
HVAC I/O Modbus Modules 2312000001$0.00The library allows the use of HVAC Modbus I/O modules of the manufacturer powerIO via a RS485 COM port. The devices are appended in the project tree and are parameterized from there without further programming effort. In the I/O Mapping area the assignments of the input/output variables can be set. The modules are available with emergency manual operation level and without. The status of the manual override is queried.
