HVAC I/O Modbus Modules
The HVAC ModbusIO2 Library enables straightforward configuration of H1.X I/O modules with minimal engineering overhead. The library provides practice‑optimized function blocks for easy use of Modbus IO modules.
This product is free to use without license acquisition (License‑free).
4.0.0.0
2312000001
Description
The HVAC ModbusIO2 Library integrates powerIO® H1.X I/O modules directly into your CODESYS V3 application. The library enables quick commissioning without complex engineering – a master function block communicates with the respective slave blocks of the I/O modules.
Description and documentation: HVAC ModbusIO2 Library
This enables you to, for example:
  • Access analog and digital inputs/outputs via Modbus RTU
  • Select sensor types (PT1000, Ni 1000, NTC 10k, etc.) directly on the function block
  • Configure I/O handling such as negation, two-point function, limit value, or filter function
  • Control 3-point actuators with the H1.4DI2DO-R-3P module
Supported Modules
  • H1.8AI – 8 analog inputs for sensor values
  • H1.8AO – 8 analog outputs (0..10V control signals)
  • H1.16DI – 16 digital inputs for signals
  • H1.8DO – 8 digital outputs
  • H1.8DO-R – 8 digital outputs with relay
  • H1.4DO-R – 4 digital outputs with relay
  • H1.4DIO-R – 4 digital inputs/outputs with relay
  • H1.4DI2DO-R-3P – for 3-point actuators
Key Features
  • Parameter window per module for slave address, bus timeout, send and query times
  • Optimized for the CFC editor
  • Safe output states before initialization (xUseSafeStateBeforeInit)
  • Ideally combinable with the HVAC Building Automation Package and the powerIO® system
All modules in shop: powerIO® Modbus I/O Modules
Development System CODESYS Development System V3.5.17.2 or higher
Runtime System CODESYS Control V4.2.0.0 or higher
Supported Platforms All CODESYS runtime systems in the version specified above
Supported Hardware powerIO® H1.X I/O modules (H1.8AI, H1.8AO, H1.16DI, H1.8DO, H1.8DO-R, H1.4DO-R, H1.4DIO-R, H1.4DI2DO-R-3P)
License-free: This product is free to use without license acquisition.
The library is provided free of charge for use with powerIO® H1.X I/O modules.
Note: Use the "Device Reader" project to determine the functions supported by the controller. "Device Reader" is available free of charge in the CODESYS Store.
powerIO GmbH
Eberhardstr. 65
70173 Stuttgart
support@powerio.com
powerIO GmbH
Eberhardstr. 65
70173 Stuttgart
www.powerio.com
