CODESYS Previous Visu Profile
This package contains all Visual Elements, Visual Styles and dependencies before CODESYS version 3.5.
000050
CODESYS Development System Version 3.5.1.0 or higher
Version Release Notes
Release Date
- 07.08.2018
