CODESYS Control for IOT2000 SL will be discontinued on October 31, 2027, as the Siemens SIMATIC IOT2000 device family is no longer available.
This product allows users to program the Siemens SIMATIC IOT-Gateway by using the free CODESYS Development System (V3).
4.23.0.0
2302000026-SW
CODESYS Control for IOT2000 SL is a SoftPLC-based on CODESYS V3 for the Siemens SIMATIC IOT2000 family (for example, IOT2020, IOT2040). After installation of the runtime environment, the PLC acts as a full-featured CODESYS controller, which can be engineered with the CODESYS Development System (V3).
Benefits
  • Enhancement of the device to the full-featured CODESYS controller
  • Application creation with the free CODESYS Development System
  • Easy programming in IEC 61131-3 languages
  • For PLCs in building, factory, and process automation, as well as training
  • Efficient engineering with the add-on products of the CODESYS Professional Developer Edition
  • Extendable runtime system (for example, MQTT, MySQL, and MsSQL from the CODESYS Store)
Interfaces
SL Extension
  • Usage of local I/Os
  • Use of external event tasks
Fieldbus support
  • CODESYS EtherCAT Master
Product options
  • CODESYS KNX SL
Siemens SIMATIC IOT family
  • Siemens Yocto V2.1 and later
    • libm.so.6
    • libpthread.so.0
    • libdl.so.2
    • librt.so.1
    • libc.so.6
    • libgcc_s.so.1
Last official release before entry in service phase Discontinuation on October 31 2027
22.10.2026
17.08.2026
18.06.2026
01.04.2026
12.02.2026
- 16.10.2025
26.08.2025
- 03.06.2025
07.04.2025
- 29.08.2024
03.07.2024
23.02.2024
Major Features of new version
  • Update to CodeMeter V7.60c
31.10.2023
- 27.07.2023
05.04.2023
25.01.2023
  • Update on CODESYS Runtime Toolkit V3.5.18.30
  • Update to CodeMeter V7.40
27.10.2022
01.03.2022
01.09.2021
Important Note
  • Fixed problems with GPIO driver
Compatiblity information
Known limitations
16.06.2021
04.03.2021
04.12.2020
19.09.2019
23.08.2019
18.04.2019
20.02.2019
17.12.2018
18.01.2019
23.10.2018
10.07.2018
13.11.2018
27.04.2018
26.02.2018
 - 20.12.2017
For more details see:
20.04.2018
16.02.2018
 - 21.09.2017
 - 22.08.2017
 - 17.07.2017
