This product is currently in the Service Phase, and its discontinuation has already been scheduled to June 30th 2026. We therefore recommend that you only use it for existing projects. Other solutions are available for new developments. We have compiled these for you on our website. Here you will also find the discontinuation dates for products in the Service Phase: Discontinuations
Control Loop Library
The “Control Loop” library includes controls, filters, and transfer functions for process control and signal processing.
1.0.1.0
000113
The “Control Loop” library includes function blocks for process control. It consists of different elements that are assembled flexibly into a control structure. These include various differentiators and integrators, for which various anti-windup strategies are available. In this way, the structure of the created control can be derived from the selected components. Some transfer functions are also achieved according to this scheme. This library also provides an example for the use of nested object-oriented function blocks.
The library also contains several digital filters that can be used for signal processing. For this purpose, it is necessary to determine the rating parameters yourself.
Development system
CODESYS Development System V3.5.14.0 or higher
Runtime
CODESYS Control V3.5.14.0 or higher
Note: Use the “Device Reader” project for locating the functions supported by the PLC. The Device Reader is available in the CODESYS Store free of charge.
Additional requirements
Required accessories
New Features:
  • Transfer Functions
The company name of the libraries has been changed to ‘CODESYS’. When upgrading to version 1.0.1.0, the old library (< 1.0.1.0) must be removed via the Library Manager and the new library must be inserted.
26.08.2024
64 bit installer support (only the package has changed)
08.09.2022
- 26.11.2019
