OSCAT BASIC
This library is a port of the OSCAT BASIC library to CODESYS Version 3.
3.3.5.0
604300
OSCAT stands for “Open Source Community for Automation Technology”.
OSCAT creates an Open Source Library referenced to the IEC 61131-3 standard which can be dispensed with vendor-specific functions and therefore ported to all IEC 61131-3 compatible programmable logic controllers. This library is a port of the OSCAT BASIC library to CODESYS Version 3.
Technical description
The library OSCAT BASIC contains functions to following subjects:
  • Buffer management
  • List processing
  • Logic
  • Math
  • Strings
  • Time and Date
Programming system
CODESYS Development System Version 3.5.10.0 or higher
Runtime system
CODESYS Control Version 3.5.10.0
All 32 bit platforms
Additional requirements
64 bit controller are not supported
Support is given by the users in the forum (see www.oscat.de). A claim for support does not exists, even if the library or parts of the library are faulty. The support in the forum under the OSCAT is provided for users voluntarily and with each other.
Version Release Notes
Release date
OSCAT: Possible out of bounds read vulnerability
For more details see CODESYS Security Advisory 2024-04, which is available on the CODESYS website:
https://customers.codesys.com/index.php?eID=dumpFile&t=f&f=18601&token=27389a52e058d95ff70b17a2370fedf07e073034&download=
10.09.2024
- Bugfixes
- Compatibility with CODESYS 3.5.16.0
- Changed LDT to LOCAL_DT for compatibility with IEC61131-3
- Changed LDT, LDATE, LTOD to LOCAL_DT, LOCAL_DATE, LOCAL_TOD
23.02.2021
