This product allows users to program different models of the WAGO Touch Panels 600 by using the free CODESYS Development System (V3).
4.23.0.0
2302000038-SW
CODESYS Control for WAGO Touch Panels 600 SL is a SoftPLC-based on CODESYS V3 for the WAGO Touch Panels 600 series. After installation of the runtime environment, the PLC can be engineered with the CODESYS Development System (V3).
Detailed information about commissioning of the PLC can be found in the CODESYS Online Help.
Benefits
  • Fully-adapted CODESYS runtime system for WAGO Touch Panels 600 series (https://www.wago.com/de/)
  • Suitable for PLC tasks with higher performance requirements
Communication
SL Extension
  • Usage of local I/Os
  • Use of external event tasks
Fieldbus
The following fieldbuses are supported by the runtime:
  • CODESYS EtherCAT Master
  • CODESYS J1939
Product options
Additonal products can be licensed for a fee:
  • CODESYS BACnet SL
  • CODESYS KNX SL
  • CODESYS Redundancy SL
  • Minimun WAGO firmware version 17
    • libm.so.6
    • libpthread.so.0
    • libdl.so.2
    • librt.so.1
    • libc.so.6
    • libgcc_s.so.1
    • libdbus-glib-1.so.2
    • libdbuskbuscommon.so.0
    • libffi.so.6
    • libglib-2.0.so.0
    • liblibloader.so.0
    • libnvram.so.0
    • libuio.so.0
    • liboms.so
    • libtypelabel.so
    • libdiagnostic.so
22.10.2026
17.08.2026
18.06.2026
01.04.2026
12.02.2026
- 16.10.2025
26.08.2025
- 03.06.2025
- 07.04.2025
03.12.2024
- 29.08.2024
03.07.2024
23.02.2024
Major Features of new version
  • Update to CodeMeter V7.60c
31.10.2023
- 27.07.2023
05.04.2023
25.01.2023
27.10.2022
30.06.2022
  • Update to CodeMeter V7.40
01.03.2022
Support of Wagos Firmware Version 12
06.12.2021
01.09.2021
Important Note
Compatiblity information
  • CODESYS SoftMotion is no longer supported as runtime option.
Known limitations
16.06.2021
Includes support of local IOs.
04.12.2020
06.05.2020
