HVAC Modbus SL
HVAC Modbus Library. Send and receive Modbus data points via RTU (serial) or TCP. Finished function blocks many manufacturers and devices from building automation. Further description: https://support.powerio.com/codesys-hvac/hvac-modbus-library/description
Without purchasing a license (just download), the HVACLibrary SL runs for 30 minutes without functional limitations and disconnects automatically (demo).
1.0.0.6
2312000013
for the usage of the “HVAC Modbus SL” Software
The following conditions are agreed between you as the software user and the company powerIO GmbH (hereinafter referred to as powerIO), 70173 Stuttgart (Germany) and are legally binding. With this license agreement, you acquire the permission of use for Software from powerIO (e. g http://store.codesys.com).
If you do not agree to the following license agreement, then you, the user, are not permitted to save and/or install the Software. Should you have already installed the Software, and you do not agree to the license agreement, then immediately delete or uninstall the Software.
§ 1          Object of the License Agreement
The object of the License Agreement is the supplied Software that you have received either directly or from the CODESYS Store. With the provided Software, the user is in the position to use and/or to extend the CODESYS Development System and/or implement a CODESYS runtime environment on a specific programmable logic controller (PLC), herein termed "device". The user has the right to install the functions of the Software after installation of the device software and/or the CODESYS Development System. In this way, the user can use the functions as specified in the data sheet of the Software.
§ 2          Geographic Restriction
§ 3          Rights of Use
The provided Software is protected by license and requires a fee. Software that is indicated as "Free" in the Store is not subject to an automatic license check by the manufacturer.
The user can, depending on availability, order a simple and non-transferable demo license to the supplied Software. The demo license is free of charge and access is limited by time and/or functionality. Once the demo license period has expired, the user can purchase a full featured license at the currently valid prices of the CODESYS Store. By doing so, the user acquires an unrestricted, simple, and non-transferable license to use the supplied Software. You need a CODESYS Soft Container or security key to be able to use the demo or full license.
All rights regarding the usage and exploitation of the software and Software remain reserved to powerIO.
§ 4          Warranty
4.1.      The manufacturer warrants that the installed Software will substantially conform to its documentation or data sheet. The following restrictions shall apply. In particular, there is no warranty that the Software fulfills the specific requirements of the user, serves his specific purpose and works together with all the other programs selected by the user, in so far as interfaces to these programs have not been agreed upon in writing.
4.2.      It is deemed to be agreed and the user recognizes and accepts that, according to the current state of knowledge and technology, it is not possible to create software in such a way that it works without errors or faults under all application conditions. A deviation from the agreed properties of the Software can only be considered significant if normal operation is substantially disrupted. If a disruption occurs under exceptional circumstances, this cannot be considered as a deviation from the agreed properties of the Software.
4.3.      The user shall immediately examine the Software supplied, shall establish its appropriateness for the intended purpose and shall immediately issue complaints about initial or non-initial errors/defects in detail and in such a way that the error/defect can be reproduced by the manufacturer. The user agrees to provide powerIO with material giving information on the nature and occurrence of these errors/defects in order to contribute to their localization and correction. The user bears sole responsibility for the selection, installation and use of the Software, as well as for the intended results thereof.
4.4.      The manufacturer does not provide a warranty for errors or defects that are caused by or result from the following circumstances:
(a)        Incorrect or insufficient maintenance or parameterization
(b)        Operation outside the software’s specification
(c)        Incorrect preparation and/or maintenance of the installation location
(d)        Interaction with hardware or software not released by the manufacturer
4.5.      Any defects with regard to the supplied Software (including defects with regard to the program description and any other documents provided along with the Software), will be rectified by the manufacturer within an appropriate period of time. The manufacturer has the right to decide between rework/repair free of charge or replacement at its own discretion.
4.6       The conditions for liability and warranty in these license terms are valid for the complete Software with respect to the manufacturer. The liability and warranty conditions of the open source licenses are valid between the user and the open source right holders.
§ 5          Limitation of Liability
§ 6          Termination
This Agreement may be terminated at any time by uninstalling from the device the described Software from the manufacturer and destroying all copies thereof.
§ 7          Governing Law
This License Agreement shall be governed by the laws of the Federal Republic of Germany excluding CISG. The place of performance and the court of jurisdiction for all disputes arising from or in connection with this agreement is 74564 Crailsheim (Germany). Claims may also be asserted against each contracting party in its general place of jurisdiction.
§ 8          Severability Clause
The HVAC Modbus SL contains function blocks for Modbus communication. The library is designed for the CFC Editor. Via a master block (serial or TCP) “slave” devices are attached. Slave devices can be single Modbus queries or completely finished device blocks from many manufacturers. This simplifies the commissioning extremely!
The HVAC Modbus Library can be perfectly complemented with the decentralized powerIO® system, which is based on working with communicative Modbus sensors and actuators. Serial stations are immediately converted to TCP and can be queried via a CODESYS controller. Further information about the decentralized system under http://www.powerio.com.
The HVAC Modbus SL library runs independently from the CODESYS Modbus library. There is no need to use a controller with CODESYS Modbus library.
In the HVAC Visu Library from the HVAC Building Automation Package SL there are Visu Frames matching the blocks.
Development System CODESYS Development System V3.5.17.2 or higher
Runtime System CODESYS Control V4.2.0.0 or higher
Supported Platforms All CODESYS runtime systems in the version specified above
Licensing Image
Single device license: The license can be used on the controller where the CODESYS runtime system is installed.
License activation is done on a software-based license container (soft container) that is permanently bound to the controller. Alternatively, the license can be stored on a CODESYS Key (USB dongle).
By plugging the CODESYS Key into a different controller, the license can be used on that controller.
Without license acquisition (download only), the library functions for 30 minutes without functional limitations (Demo).
Note: Use the "Device Reader" project to determine the functions supported by the controller. "Device Reader" is available free of charge in the CODESYS Store.
powerIO GmbH
Eberhardstr. 65
70173 Stuttgart
support@powerio.com
powerIO GmbH
Eberhardstr. 65
70173 Stuttgart
www.powerio.com
Initital Release 24.11.2020
