OSCAT NETWORK
This library is a port of the OSCAT NETWORK library to CODESYS Version 3.
1.3.5.2
604301
OSCAT stands for “Open Source Community for Automation Technology”.
OSCAT creates an Open Source Library referenced to the IEC 61131-3 standard which can be dispensed with vendor-specific functions and therefore ported to all IEC 61131-3 compatible programmable logic controllers. This library is a port of the OSCAT NETWORK library to CODESYS Version 3.
Technical description
The library OSCAT NETWORK contains functions to following subjects:
  • String conversion und encryption
  • Data log
  • Files (INI- and CSV Reader)
  • Network (e.g. FTP, HTTP, SMTP, SNTP, Telnet)
  • Weather information
CODESYS Development System Version 3.5.10.0 oder höher
CODESYS Control Version 3.5.10.0
Alle 32 Bit Plattformen
64 Bit Controller werden nicht unterstützt
Support is given by the users in the forum (see www.oscat.de). A claim for support does not exists, even if the library or parts of the library are faulty. The support in the forum under the OSCAT is provided for users voluntarily and with each other.
Version Release Notes
Release date
Compatibility with CODESYS 3.5.16.0
Bugfixes
05.03.2021
Compatibility with CODESYS 3.5.16.0 23.02.2021
Bugfix in function block 'FILE_SERVER' for CODESYS 3.5.11.0 and higher. 05.10.2017
- 02.07.2013
