Search results for: 'profinet controller'
 - controller softplc 149
 - controller plc 153
 - controller+plc 153
 - controller+softplc 149
 - controller sl 129
CODESYS Application Composer L is suited for medium to large machines with up to 2500 modules.
CODESYS Application Composer S is suited for small to large machines with up to 500 modules.
CODESYS Application Composer S is suited for small to medium machines with up to 100 modules.
CODESYS Application Composer XL is suited for large and huge machines with up to 12,500 modules.
                    Dweet Pro Library SL 2312000003$60.00 As low as $48.60This is an unofficial library for use with the dweet.io and dweetpro.io service. It’s developed to use with the main features as sending and receiving dweets. The library supports a secure connection between the service and the PLC controller. TLS encrypts all traffic. The dweet service also offers the opportunity to protect your “Thing” with a secret key.
Without purchasing a license (just download), the Dweet Library SL runs for 30 minutes without functional limitations and disconnects automatically (demo).
                    CODESYS Sensor App for Android 000073$0.00With the product “CODESYS Sensor App for Android”, the sensor data of from an Android smartphone can be sent to a CODESYS controller.
                    CODESYS V3 Essentials Training - LIVE ONLINE - Feb 2026 2108100015-T-2026-2-2$1,500.00Available: 20 of 20Feb 2, 2026 (11:00 EST) - Feb 5, 2026 (16:00 EST)
                    CODESYS V3 Essentials Training - LIVE ONLINE - Dec 2025 2108100015-T-2025-12-15$1,500.00Available: 9 of 12Dec 15, 2025 (11:00 EST) - Dec 18, 2025 (16:00 EST)
