The application-based CODESYS Control Standard S license is specially designed for applications with a complex fieldbus instance. It contains 512 I/O channels and can be used on all Control SL products without restrictions.
License Control Standard S
Metric
Basic L
Standard S
Standard M
Fieldbus instances
2
4
8
Complex fieldbus instances
1
1
1
thereof host instances
0
1
1
1
1
1
Number of I/O channels
256
512
1024
Visu S
Visu S
Visu S
Communication
Communication S
Communication S
Communication S
DataSource Manager
Yes
Yes
Yes
Dynamic C code
No
Yes
Yes
No
No
No
CODESYS Communication
CODESYS Visualization
CODESYS SoftMotion Axes
Description of properties
Trial Operation
License check
Upgrade licenses
Which fieldbus is needed? How many fieldbus master?
How many input and output channels are needed in the application?
Do you plan to implement additional functions and logics?
Do you want to assign tasks or task groups to specific cores to achieve higher performance or optimized realtime behavior?
2 CANopen master: at least license Basic M
Option: One EtherCAT master: at least license Standard S
200 I/O channels: at least license Basic L
Real-time behavior: In the range of 4-10 ms
One EtherCat master: at least license standard S
800 E-A channels: at least license standard M
Separation of the bus task on its own core : at least standard L
Connection C code: Dynamic C code included in Standard L.
One Profinet master: at least license standard S
1,500 E-A channels: at least license standard L
HMI for maintenance: at least CODESYS Visualization M
Use of MQTT: CODESYS IIoT Libraries SL license is required.
One EtherCAT master: at least license standard S
200 I/O channels: License Standard S is sufficient
Increased real-time requirement: at least Standard L to use multi-core functionality.
Control of 8 axes in total: SoftMotion Axis (8) license for 8 axes
Control of 2D portal and SCARA robot: SoftMotion Axis Groups/CNC Interpolators (2) for 2 axis groups
CODESYS Control Win SL
CODESYS Control for Linux SL
CODESYS Virtual Control SL
CODESYS Control for PFC100 SL
CODESYS Control for PFC200 SL
Updates
Symbolic data source objects are not supported on Linux-based systems
