Matrikon® FLEX™ OPC UA Editor
This CODESYS plug-in editor allows configuration of the OPC UA server, communication settings and setup of data to be exposed over OPC UA. The Matrikon FLEX OPC UA server stack needs to be implemented in the controller’s firmware and linked to the CODESYS Control Runtime System with an additional runtime system component (CmpMatrikonOPCUAserver).
This package provides a full evaluation system for Beagle Bone Black platforms, including full documentation.
000112
Server configuration
  • Device Ethernet interface
  • Cycle rate
Communication settings
  • IP address / Port
  • Number of sessions
  • Reverse connect (client to server)
Data setup
  • Upload of all variables in the application
  • Access rights
  • Data types
  • Engineering units
  • Ranges
  • Sample rates
From CODESYS Development System V3.5.9.x
Target System
CODESYS Control V3.x.x
Supported Platforms / Devices
All platforms compatible with the Matrikon FLEX OPC UA stack and integrating the Matrikon FLEX OPC UA server stack and the CmpMatrikonOPCUAserver runtime component. Evaluation target platform: BeagleBone Black from Version C
The editor requires Microsoft .NET framework 4.6.2
none
Required Accessory
For evaluation: BeagleBone Black board and CODESYS Control for BeagleBone SL
Required Accessory
Support On Behalf Provided by:
BE.services GmbH
Tel: +49 831 960 699 91
info@be-services.com
Matrikon
Matrikon International Inc.
Suite 1800
10405 Jasper Avenue Edmonton Alberta, T5J-3N4
Canada
