CODESYS Security Agent
The feature „CODESYS Security Agent“ is designed to configure and control security-related issues in a CODESYS environment. The Addon is available in the CODESYS Store and will be extended stepwise in future versions.
1.6.0.0
000093
CODESYS Security Agent offers an operator different security-related functions. It extends the Security Screen in the CODESYS Development System.
CODESYS Development System V3.5.19.0
CODESYS Control V3.5.14.0
Note: The scope of the available security functions depends on the applied CODESYS Runtime System and may vary.
- 29.10.2026
- 27.05.2026
- 24.06.2025
- 05.07.2022
- 29.01.2021
- 27.10.2020
Usability update:
  • Added wizard for certificate-based encryption of boot application
24.01.2019
- 08.08.2018
