Dweet Pro Library SL
This is an unofficial library for use with the dweet.io and dweetpro.io service. It’s developed to use with the main features as sending and receiving dweets. The library supports a secure connection between the service and the PLC controller. TLS encrypts all traffic. The dweet service also offers the opportunity to protect your “Thing” with a secret key.
Without purchasing a license (just download), the Dweet Library SL runs for 30 minutes without functional limitations and disconnects automatically (demo).
- Buy 4 for $57.00 each and save 5%
- Buy 10 for $54.60 each and save 9%
- Buy 25 for $51.00 each and save 15%
- Buy 50 for $48.60 each and save 19%
