Search results for: 'used be'
- used to in 76
- used license 111
- used to is 111
- used f 118
- used support 85
CODESYS V3 Intensive Training - Temecula, CA - Sept 2026 2108100012-T-2026-09-20$2,750.00Available: 1 of 9Sep 28, 2026 (08:00 PDT) - Oct 1, 2026 (17:00 PDT)
43044 Business Park Drive, Temecula, CA, 92590-3614This 32-hour training is targeted for experienced control engineers transitioning to CODESYS, or for engineers wishing to take their knowledge of CODESYS to the next level. It combines basic and advanced training modules to give participants a comprehensive understanding of the capabilities of CODESYS, alternating between lectures and hands-on labs. It includes hints, tricks, and best practices compiled from many years of experience.
This training will be hosted by Opto 22 and will include a 1-hour factory tour and real-world experience with Opto 22 PLCs and hardware.
