CODESYS Control for PFC100 SL
This product allows users to program the WAGO PFC100 controller by using the free CODESYS Development System (V3).
4.23.0.0
2302000019-SW
CODESYS Control for PFC100 SL is a SoftPLC-based on CODESYS V3 for the WAGO PFC100 industrial PLC. After installation of the runtime environment, the PLC can be engineered with the CODESYS Development System (V3).
  • Download of the product “CODESYS Control for PFC100 SL” from the CODESYS Store (http://store.codesys.com)
  • Installation of CODESYS SoftPLC on a WAGO PFC100 device (http://www.wago.com)
Benefits
Interfaces
SL Extension
  • Usage of local I/Os
  • Use of external event tasks
  • Connect persistent memories (Retains
Fieldbus support
  • CODESYS CANopen Manager / Device (except 750-8102 / -8112)
  • CODESYS EtherCAT Master
  • CODESYS J1939
  • CODESYS Modbus Serial Master / Slave (only 750-8102 / -8112)
Product options
  • CODESYS KNX SL
  • CODESYS Redundancy SL
All models of the WAGO PFC100 family
  • Minimum WAGO firmware version 17
    • libm.so.6
    • libpthread.so.0
    • libdl.so.2
    • librt.so.1
    • libc.so.6
    • libgcc_s.so.1
    • libdbus-glib-1.so.2
    • libdbuskbuscommon.so.0
    • libffi.so.6
    • libglib-2.0.so.0
    • liblibloader.so.0
    • libnvram.so.0
    • libuio.so.0
    • liboms.so
    • libtypelabel.so
    • libdiagnostic.so
  • The software package does not support hardware-specific model variations.
22.10.2026
17.08.2026
18.06.2026
01.04.2026
12.02.2026
- 16.10.2025
26.08.2025
- 03.06.2025
- 07.04.2025
03.12.2024
- 29.08.2024
03.07.2024
23.02.2024
Major Features of new version
  • Update to CodeMeter V7.60c
31.10.2023
- 27.07.2023
05.04.2023
25.01.2023
27.10.2022
30.06.2022
  • Update to CodeMeter V7.40
01.03.2022
06.12.2021
01.09.2021
Important Note
Compatiblity information
Known limitations
16.06.2021
04.03.2021
04.12.2020
  • Support of WAGO firmware version 03.00.35(12)
23.08.2019
18.04.2019
20.02.2019
17.12.2018
18.01.2019
23.10.2018
10.07.2018
13.11.2018
24.05.2018
27.04.2018
26.02.2018
 - 20.12.2017
For more details see:
20.04.2018
16.02.2018
 - 21.09.2017
 - 22.08.2017
 - 17.07.2017
