CODESYS Edge Gateway for Windows
The CODESYS Edge Gateway is an extended CODESYS Gateway connecting the CODESYS Automation Server to CODESYS PLCs in a local network.
3.5.22.40
000110
The CODESYS Edge Gateway allows the CODESYS Automation Server and all clients that establish a connection via the Automation Server (CODESYS, Webvisu/Browser) full access to all services provided by the runtime system via communication interfaces. It can be operated on a controller or on a stand-alone device in the local network.
CODESYS Development System Version 3.5.15.0 or higher (Only required for the configuration of the gateway)
CODESYS Control V3.5 SP10 or higher
  • Windows 8 / 10 (32/64 Bit), suitable PC hardware for the corresponding Windows platform
  • Access to a CODESYS Automation Server
  • Installation of CODESYS Automation Server Connector plug-in
  • Reliable system clock on the target device running the CODESYS Edge Gateway.
Currently no support for CODESYS V2 PLCs.
Includes the following Security fixes: 2026-11
30.09.2026
- 23.07.2026
Includes the following Security fixes: 2025-09
20.05.2026
02.04.2026
24.03.2026
22.04.2026
01.12.2025
- 25.09.2025
- 04.08.2025
- 26.05.2025
- 18.03.2025
- 21.05.2026
- 22.04.2025
- 24.01.2025
- 21.11.2024
- 23.09.2024
- 31.07.2024
Includes the following Security fixes: 2024-02
04.06.2024
- 19.03.2024
- 02.05.2024
- 06.02.2024
- 04.12.2023
- 23.10.2023
- 05.10.2023
- 03.08.2023
- 01.06.2023
Includes the following Security fixes: 2023-03
08.03.2023
- 31.10.2023
- 04.05.2023
- 13.12.2022
- 06.10.2022
03.06.2022
Includes the following Security fixes: 2021-12, 2022-04, 2022-06
06.04.2022
- 02.02.2023
- 28.10.2022
- 10.06.2022
- 25.01.2022
02.11.2021
23.07.2021
Includes the following Security fixes: 2021-01, 2021-04
28.04.2021
- 27.07.2022
Includes the following Security fixes: 2021-04
18.11.2021
- 18.08.2021
- 26.05.2021
28.01.2021
Quality update with minor improvements and bug fixes..
19.11.2020
We strongly recommend to replace all existing CODESYS Edge Gateway - BETA VERSIONs by CODESYS Edge Gateway V3.5.15.10 or higher.
24.09.2019
18.02.2026
