Search results for: 'control medicao'
- control media
- control softplc),).',",(. 157
- controller softplc 157
- controller plc 160
- controller+plc 161
- controller+softplc 157
CODESYS 3 Essentials Training - Green Bay, WI - Oct 2026 2108100015-T-2026-10-13-1$1,500.00Oct 13, 2026 (08:00 CDT) - Oct 15, 2026 (17:00 CDT)
1015 Lombardi Ave, Green Bay, WI 54304This new and improved training is targeted for individuals who are new to CODESYS and are looking to build a strong foundation in controls and automation. Through a mix of lectures, examples, and hands-on exercises, this class will cover the basic features of CODESYS and the various IEC 61131-3 programming languages.
