MySQL Library SL
The MySQL Library SL enables a direct connection between a MySQL database and a CODESYS V3 controller application to read and write data – without additional drivers or software on the controller.
Without license acquisition (download only), the MySQL Library SL operates for 30 minutes without functional limitations (Demo).
2.0.0.0
2112000006
$120.00
  • Buy 4 for $114.00 each and save 5%
  • Buy 10 for $109.20 each and save 9%
  • Buy 25 for $102.00 each and save 15%
  • Buy 50 for $97.20 each and save 19%
This Library allows your CODESYS V3.5 application, to connect with a MySQL-Server data-base. It gives you the opportunity to read and store process data to an external or internal SQL database, without any 3rd party software or driver. Whether you want to store data for long-term logging, exchange data with 3rd party applications or collecting mass of machine data for your next IoT project, it’s all possible with our MySQL-Library for CODESYS.
You will be able to connect to a MySQL-Server, which is directly running on the same sys-tem, as your PLC (local) or you can also connect to a remote hosted MySQL-Server, any-where in the world.
MySQL is a fast, easy-to-handle, and lightweight database system and compatible with most of the well-known operating systems.
Development System CODESYS Development System V3.5.17.2 or higher
Runtime System CODESYS Control V4.2.0.0 or higher
Supported Platforms All CODESYS runtime systems in the version specified above
Licensing Device License
Single device license: The license can be used on the controller where the CODESYS runtime system is installed.
License activation is done on a software-based license container (soft container) that is permanently bound to the controller. Alternatively, the license can be stored on a CODESYS Key (USB dongle). By plugging the CODESYS Key into a different controller, the license can be used on that controller.
Without license acquisition (download only), the library functions for 30 minutes without functional limitations (Demo).
License: MySQL Library License SL
Note: Use the "Device Reader" project to determine the functions supported by the controller. "Device Reader" is available free of charge in the CODESYS Store.
powerIO GmbH
Eberhardstr. 65
70173 Stuttgart
support@powerio.com
powerIO GmbH
Eberhardstr. 65
70173 Stuttgart
www.powerio.com
