The CODESYS Modbus Serial Server SL is not compatible with application-based licenses.
The CODESYS Modbus Serial Server enables a controller to act as a Modbus serial server that is programmable with the CODESYS Development System.
2303000019
$60.00
The CODESYS Modbus Serial Server enables a CODESYS-capable controller to register as a Modbus serial server in a Modbus network. For CODESYS-compatible controllers can use this functionality, they require a COM port for communication. The CODESYS Modbus Serial Server product integrates this functionality seamlessly into the existing controller. During project engineering, the Modbus Serial Device is included in the device tree of an IEC 61131-3 project. Then configuration is performed directly in the development environment.
  • CODESYS Control runtime system on the device with SysCom component
  • Available serial port on the device
