Search results for: 'PLCnext SL'
- plcnext sl runtime 12
- PLCnext SL safety 3
- plcnext mx 3
- plcnext+sl+runtime 12
- plcnext license 84
MySQL Library SL 2112000006$85.00 As low as $68.85This Library allows you to connect your CODESYS v3.5 application to a MySQL-Sever database to read and write data from it.
Without purchasing a license (just download) the MySQL Library SL runs for 30 minutes without functional limitations and disconnects automatically (demo).
HVAC Modbus SL 2312000013$0.00HVAC Modbus Library. Send and receive Modbus data points via RTU (serial) or TCP. Finished function blocks many manufacturers and devices from building automation. Further description: https://support.powerio.com/codesys-hvac/hvac-modbus-library/description
CODESYS Virtual Safe Control SL 000139Safety without compromise: With CODESYS Virtual Safe Control SL, you get a certified SIL3 controller without any special hardware requirements. Install it on your commercial-of-the-shelf hardware and experience maximum safety - only with CODESYS.
