CODESYS Control for Raspberry Pi SL
CODESYS Control for Raspberry Pi SL is an adapted CODESYS Control runtime system for the Raspberry Pi (PLC extension), for non-commercial use. If the device is to be used commercially, application based licenses must be used.
4.23.0.0
2302000009
$66.00
CODESYS Control for Raspberry Pi SL contains a CODESYS Control application for all Raspberry Pi, including the Compute Module (see http://www.raspberrypi.org/) as well as the capability to use the extension modules and several devices/breakouts with SPI, I²C or 1-wire communication interface.
This product can be installed with the included CODESYS Deploy Tool plug-in via the CODESYS Development System on the Raspberry Pi’s Linux system. After each restart the runtime system will be started automatically. If no valid full license can be found, CODESYS Control runs for two hours without functional limitations before shut down.
Detailed information can be found in the Online Help.
Interfaces
The CODESYS device description does support the following components:
  • CODESYS OPC UA Server, as full version for data exchange
  • CANopen via EL6751 Gateway
  • Raspberry Pi Camera
  • I²C interface, with SenseHat, SRF02, Adafruit PWM, MPU6050 Gyro, MPU9150 Gyro, AK8975 Compass
  • SPI interface, with MCP3008, MCP23S17, PiFace Digital, PiFace Control Display
  • One-wire interface, with DS20B18
  • GPIO
SL Extension
  • Usage of local I/Os
  • Use of external event tasks
Fieldbus support
  • CODESYS EtherCAT Master
  • CODESYS J1939
Product options
  • CODESYS BACnet SL
  • CODESYS KNX SL
  • CODESYS Redundancy SL
  • CODESYS SoftMotion
  • CODESYS SoftMotion Light SL
All Pi models
  • The CODESYS Control requires a network interface (LAN, WLAN), especially with the Raspberry Pi Compute Module and the Raspberry Pi ZERO.
  • If the product is used for industrial purposes, it is the responsibility of the system manufacturer to ensure compliance with the necessary specifications.
  • The operating system Raspberry Pi OS (32-bit or 64-bit) https://www.raspberrypi.org/downloads/
    • libm.so.6
    • libpthread.so.0
    • libdl.so.2
    • librt.so.1
    • libc.so.6
    • libgcc_s.so.1
  • The combination of Raspberry Pi and a CODESYS Runtime is for private use, test and teaching purposes. Commercial use is not permitted.
Private license (non-commercial use). More details can be found in the License Agreement.
  • SD-card (minimum 4GB)
  • Optional: CODESYS Key
  • The runtime is now started and managed by systemd
  • Fix: On Raspberry Pi 5, GPIOs are released on “Reset origin” and stay usable
  • Fix: The SoftMotion servo example now references the correct library
22.10.2026
  • SenseHat library joystick input works correctly on 64bit and 32bit devices
17.08.2026
18.06.2026
01.04.2026
12.02.2026
16.10.2025
Update on CODESYS Runtime Toolkit V3.5 SP21 P2
26.08.2025
Update on CODESYS Runtime Toolkit V3.5 SP21 P1 03.06.2025
Update on CODESYS Runtime Toolkit V3.5 SP21 07.04.2025
03.12.2024
Support of network licensing
29.08.2024
03.07.2024
23.02.2024
Major Features of new version
  • Update to CodeMeter V7.60c
  • Full 64bit CODESYS Control SL runtime
31.10.2023
- 27.07.2023
05.04.2023
25.01.2023
27.10.2022
30.06.2022
- 01.03.2022
01.09.2021
Important Note
  • Fixed problem with GPIO outputs
Compatiblity information
Known limitations
16.06.2021
04.03.2021
04.12.2020
Quality update with minor improvements and bug fixes. Includes fix for latest Raspberry Pi OS version.
  • Quality update with minor improvements and bug fixes
  • Support of Pi4
19.09.2019
  • Support the new model Raspberry Pi 3 Model A+
  • Removal of SoftMotion widget type="Codesys\AllVersionWidget\Block\Widget\AllVersion" - available as separate product
23.08.2019
18.04.2019
20.02.2019
  • Includes security fixes 2018-07 to 2018-14 (Details)
14.12.2018
