CODESYS Control Win SL
CODESYS Control Win SL is an IEC 61131-3 SoftPLC for PC-based industrial controllers (PLCs) under Windows with soft real-time properties.
3.5.22.40
2302000003-SW
The CODESYS Control Win SL turns an industrial PC into a universally usable high-performance PLC - almost arbitrarily scalable via the PC performance. The system is suitable for applications without tough requirements on real-time behavior and is equipped with the add-on CODESYS KNX SL is also used in buildings.
The runtime system supports numerous I/O interfaces such as discrete input/output or fieldbus cards as well as integrated IEC 61131-3 protocol stacks. The fieldbuses are configured directly in the CODESYS Development System - without the use of additional tools.
Benefits
  • Communication with the CODESYS Development System
  • Loading, management and execution of the application code compiled by CODESYS in binary format
  • Debugging of the application within CODESYS
  • Handling of the I/O systems and fieldbuses
  • Execution of optional components (see section “Product options”)
  • Support of remanent data: hard disk, flash card, battery buffered SRAM card
Interfaces
Fieldbus support
  • CODESYS EtherCAT Master [1]
  • CODESYS EtherNet/IP Scanner / Adapter [1]
  • CODESYS J1939
  • CODESYS Modbus TCP Master / Slave [1]
  • CODESYS PROFIBUS Master
  • CODESYS PROFINET Controller / Device [1]
  • CODESYS Sercos III Master
Product options
The product can be extended by the following chargeable product options:
  • CODESYS BACnet SL
  • CODESYS KNX SL
  • CODESYS Redundancy SL
  • CODESYS SoftMotion SL
  • CODESYS TargetVisu
  • CODESYS WebVisu
Minimum CODESYS Development System V3.5 SP19 Patch 1 (recommended V3.5 SP20 or higher)
Minimum CODESYS Control Win SL V3.5 SP19 Patch 1 or higher
Supported Windows Versions: Windows 10 / 11 / IoT Enterprise 64 Bit, with Multicore-CPUs
Additional requirements
Installation of CODESYS Control Win SL
No “ hard” real time / Soft real-time properties: within the tolerance range time can be exceeded frequently and, secondly, rarely by a large amount.
Two types of licensing are offered:
  1. Application-based licensing: Since v3.5.19.0 The size and features of the IEC application are licensed.
  2. Single device license: The license can only be used by one exclusive controller (legacy licensing model).
The license is activated on a software-based license container (soft container) that is permanently linked to the controller. Alternatively, the license can be stored on a CODESYS key (USB dongle). By reconnecting the CODESYS Key, the license can be used on another controller.
Note: Without a license, the software runs in demo mode for two hours. After that, a manual restart is required.
Includes the following Security fixes: 2026-11, 2026-12
30.09.2026
- 23.07.2026
20.05.2026
- 02.04.2026
24.03.2026
- 22.04.2026
01.12.2025
- 25.09.2025
Includes the following Security fixes: 2025-07, 2025-08
04.08.2025
- 26.05.2025
- 18.03.2025
- 21.05.2026
- 22.04.2025
- 23.01.2025
- 20.11.2024
23.09.2024
- 31.07.2024
Includes the following Security fixes: 2024-02, 2024-03
04.06.2024
- 19.03.2024
- 02.05.2024
- 04.12.2023
- 23.10.2023
05.10.2023
Includes the following Security fixes: 2023-05, 2023-06, 2023-07, 2023-08
03.08.2023
- 01.06.2023
08.03.2023
31.10.2023
04.05.2023
13.12.2022
06.10.2022
Includes the following Security fixes: 2022-09, 2022-10
03.06.2022
Includes the following Security fixes: 2021-09, 2021-11, 2021-12, 2022-02, 2022-03, 2022-04, 2022-06, 2022-07
06.04.2022
- 02.02.2023
- 28.10.2022
- 10.06.2022
- 25.01.2022
02.11.2021
23.07.2021
28.04.2021
- 27.07.2022
- 18.11.2021
18.08.2021
26.05.2021
28.01.2021
19.11.2020
22.06.2020
19.09.2019
23.08.2019
- 18.04.2019
20.02.2019
17.12.2018
16.05.2019
18.01.2019
23.10.2018
23.08.2018
10.07.2018
13.11.2018
18.09.2018
17.07.2018
24.05.2018
27.04.2018
15.03.2018
For more details see:
26.02.2018
- 20.12.2017
20.04.2018
16.02.2018
- 17.11.2017
.- 17.10.2017
- 21.09.2017
- 22.08.2017
- 13.07.2017
- 20.09.2017
- 23.08.2017
- 17.07.2017
- 22.05.2017
- 21.04.2017
- 16.03.2017
- 14.02.2017
- 15.12.2016
- 18.04.2017
- 18.02.2026
