CODESYS KNX SL
CODESYS KNX consists of a configurator for I/O channels, a KNXnet/IP protocol stack in the form of a runtime system component, and a data exchange function with the ETS5 configuration system. This allows any CODESYS-compatible device to be expanded to function as a KNX subscriber and to communicate with KNX I/Os.
4.0.2.0
2303000232
$180.00
To use the function, the integrated data channels of the CODESYS controller are exported to an XML format, imported into ETS5 and integrated into an overall configuration. The required data (“associations”) are transferred to the CODESYS runtime system. The input and output data integrated in this way can be provided with an intelligent logic function in CODESYS. At the same time, users can transfer the data to other bus protocols, for example via BACnet or OPC UA. Thus, the Industry 4.0 features of the tool allow for building automation to be networked with SmartFactory or SmartEnergy systems.
CODESYS Development System Version 3.5.13.0 or higher
CODESYS Control V3.5.14.0 or higher
  • CODESYS Control Win V3
  • Raspberry Pi
  • BeagleBone Black
  • PFC100
  • PFC200
  • IOT2000
  • emPC A/iMX6
  • ETS5 and CODESYS DCA for ETS5
  • CODESYS Development System V3.5 SP16 requires CODESYS KNX V4.0.1.0 as minimum version
- 10.06.2021
Quality update with bug fixes.
26.03.2020
  • KNX has been transformed to a CODESYS AddOn (has been an integrated CODESYS-Component in prior releases)
  • Converter functions for KNX DPTs Time and DateTime
31.01.2019
