CODESYS SoftMotion Light SL
CODESYS SoftMotion Light extends the functional range of CODESYS Control SL systems from pure logic to motion control.
4.20.2.0
2305000002
$231.00
CODESYS SoftMotion Light allows to command CiA 402 compatible drives for single axis movements (not synchronized).
In contrast to SoftMotion Axes and SoftMotion Axis Groups/CNC Interpolators, the calculation of the axis movements is not done within the controller. With SoftMotion Light movements of the drive are just commanded and supervised (status) by the PLC and executed by the drive. The trajectory calculation is done in the drive.
SoftMotion Light is suitable for applications with multiple axes for single axes movements and for controller tasks requiring a low bus and computing load (CPU).
All supported by CODESYS:
WIBU Codemeter Support
- 27.11.2025
- 18.11.2025
- 02.09.2025
- 11.04.2025
- 30.07.2024
- 20.01.2026
