The CODESYS Profibus Master (for EL6731) SL is not compatible with application-based licenses.
CODESYS Profibus Master (for EL6731) SL is a product that allows end users to integrate their devices as a Profibus master into a Profibus network.
2303000012
$180.00
The EL6731 gateway terminal from Beckhoff allows an EtherCAT enabled controller to register itself as a Profibus master in a Profibus network. For this purpose, a specific CODESYS compatible controller with EtherCAT fieldbus support is licensed accordingly. This product allows the integration of the terminal into an EtherCAT tree and the configuration directly from withing the CODESYS Development System. For CODESYS compatible controllers to use this functionality, they require the EL6731 Profibus master gateway. End users of CODESYS compatible controllers with EtherCAT are provided with the option for configuring their device as a Profibus master and integrating it into existing Profibus architectures.
CODESYS Development System V3.5.4.0 or higher
CODESYS Control V3.5.4.0 or higher
  • Available EtherCAT Master and Ethernet port on the device
  • WIBU Codemeter support
  • PROFIBUS master terminal EL6731 (Beckhoff)
  • Optional: CODESYS Key
