Search results for: 'raspberry+codesys'
CODESYS Automation Server On-Prem 500 2315000023 Subscription$17,976.00With the CODESYS Automation Server On-Prem 500 license, you connect up to 500 PLCs to your CODESYS Automation Server On-Prem. The license is offered as a one-year subscription and can be booked multiple times to connect additional PLCs.
CODESYS Automation Server On-Prem 250 2315000022 Subscription$8,988.00With the CODESYS Automation Server On-Prem 250 license, you connect up to 250 PLCs to your CODESYS Automation Server On-Prem. The license is offered as a one-year subscription and can be booked multiple times to connect additional PLCs.
CODESYS Automation Server On-Prem 100 2315000021 Subscription$3,595.00With the CODESYS Automation Server On-Prem 100 license, you connect up to 100 PLCs to your CODESYS Automation Server On-Prem. The license is offered as a one-year subscription and can be booked multiple times to connect additional PLCs.
