CODESYS File-Based Storage offers an alternative project storage format for CODESYS. In contrast to normal, binary project storage, projects are stored text-based in a folder structure similar to the project tree.
CODESYS File-Based Storage is part of the CODESYS Professional Developer Edition tool bundle.
The normal CODESYS project storage creates a single binary file whose contents cannot be read or created by other tools.
CODESYS File-Based Storage, on the other hand, stores a project as a folder tree on disk that mirrors the project tree. One or more text files are created for each object, and these files can be processed or even created by other text editors: IEC source code as plain text, project metadata as JSON.
Typical use cases:
The path towards CODESYS 4 – CODESYS 4 stores projects file-based natively. For libraries the format is identical: a library converted to .fbslib is already stored in the format that CODESYS 4 reads and writes. For development projects, the conversion step will follow in upcoming versions.
Automation in CI/CD – the scripting interface opens, converts and validates projects without a user interface.
Analysis and tooling – the whole project can be searched and statically checked with familiar tools.
The format is open and documented. Read access from outside CODESYS is supported, but projects are edited in the CODESYS Development System: whether a change written from outside results in a valid project is decided only when CODESYS loads and builds it. Note that CODESYS V3 does not allow inconsistencies in the project – it may be impossible to open or display projects with an invalid status.
For use in the context of Git, we advise you to use the upcoming CODESYS Git 2.0.0.0 or later. It understands both the storage format and the CODESYS project model and therefore ensures that all files belonging to a project are committed together and in a consistent state.
For object types for which there is not yet a suitable storage format, the xml-based export format is used.
CODESYS Development System V3.5.22.0 or higher
Subscription of the CODESYS Professional Developer Edition
Recommended for version control: the upcoming CODESYS Git 2.0.0.0 or later
For use in CI/CD pipelines, the build agent requires a CODESYS installation with the File-Based Storage add-on and a valid license. Headless means without an interactive user interface, not without a CODESYS installation.
A login without online change to a running existing application with a new file-based project may work but cannot be guaranteed.
A previously installed earlier version (< 1.0.0.0) must be uninstalled. In addition, the file FileBasedStorage.dll must be deleted from the Common directory.
Due to the file-based concept, many individual files are processed when opening and saving a project instead of a single binary file. Loading and saving can therefore take longer than with binary project storage.
see CODESYS Professional Developer Edition
Without a valid license, file-based projects open read-only and the Save command is disabled.
Required accessories
