CODESYS Automation Server Connector
The CODESYS Automation Server Connector is an Add-on for the CODESYS Development System to synchronize projects on the CODESYS Automation Server and to configure CODESYS Edge Gateways.
1.39.0.0
000107
Two use cases are covered by the CODESYS Automation Server Connector:
Synchronization of projects and applications
With the “Application Repository” functionality, project sources and associated applications can be managed on the CODESYS Automation Server. The connection between CODESYS Automation Server and CODESYS Development System is done by the CODESYS Automation Server Connector. It enables projects to be checked out as a local working copy and project changes to be synchronized in the cloud.
Configuration of CODESYS Edge Gateway
The local PLCs connect to the CODESYS Automation Server via the CODESYS Edge Gateway. The gateway is configured via the CODESYS Automation Server Connector. The URL of the CODESYS Automation Server is transferred to the CODESYS Edge Gateway. Certificates are created and exchanged for a secure TLS connection.
Note: The communication between the CODESYS Automation Server Connector and the CODESYS Edge Gateway is unencrypted. Therefore, it is important to configure a CODESYS Edge Gateway in a secure network.
CODESYS Development System V3.5.15.0 or higher
Requires access to a CODESYS Automation Server
- 08.07.2026
- 24.11.2025
