Search results for: '2.3 codesys'
- 23 26 2 3 codesys
- 23 23 2 3 codesys
- Codesys project 200
- codesys party 200
- codesys product 201
- codesys products 201
- codesys third 200
CODESYS Automation Server On-Prem 500 2315000023 Subscription$17,976.00With the CODESYS Automation Server On-Prem 500 license, you connect up to 500 PLCs to your CODESYS Automation Server On-Prem. The license is offered as a one-year subscription and can be booked multiple times to connect additional PLCs.
CODESYS Automation Server On-Prem 250 2315000022 Subscription$8,988.00With the CODESYS Automation Server On-Prem 250 license, you connect up to 250 PLCs to your CODESYS Automation Server On-Prem. The license is offered as a one-year subscription and can be booked multiple times to connect additional PLCs.
CODESYS Automation Server On-Prem 100 2315000021 Subscription$3,595.00With the CODESYS Automation Server On-Prem 100 license, you connect up to 100 PLCs to your CODESYS Automation Server On-Prem. The license is offered as a one-year subscription and can be booked multiple times to connect additional PLCs.
