CODESYS SoftMotion Axis Groups/CNC Interpolators (3)
With this product 3 axis groups or CNC interpolators can be controlled.
2305000017
$528.00
Functional principle
  • Integrated motion planning:
Typical applications
All supported by CODESYS:
WIBU Codemeter Support
