We will be closed Wednesday, December 24 and Thursday, December 25.
The following week, we will be closed on Wednesday, December 31 and Thursday, January 1.
CODESYS SoftMotion Axes (4)
With this license, up to 4 real axes, and additionally 4 virtual axes, can be controlled.
2305000009
$192.00
Functional principle
Typical applications
All supported by CODESYS:
WIBU Codemeter Support
