CODESYS Control Standard L
The application-based CODESYS Control Standard L license is specially designed for applications with two complex fieldbus instances. It contains 4096 I/O channels and can be used on all Control SL products without restrictions.
2302000052
From $239.00
License Control Standard L
Metric
Standard M
Standard L
Performance M
Fieldbus instances
8
10
12
Complex fieldbus instances
1
2
4
thereof host instances
1
2
4
1
2
4
Number of I/O channels
1024
4096
8192
Visu S
Visu S
Visu S
Communication
Communication S
Communication S
Communication S
DataSource Manager
Yes
Yes
Yes
Dynamic C code
Yes
Yes
Yes
No
Yes
Yes
CODESYS Communication
CODESYS Visualization
CODESYS SoftMotion Axes
Description of properties
Trial Operation
License check
Upgrade licenses
  • CODESYS Control Win SL
  • CODESYS Virtual Control SL
Updates
