CODESYS Control Standard M
The application-based CODESYS Control Standard M license is specially designed for applications with an Ethernet-based fieldbus instance. It contains 1024 I/O channels and supports an application size of up to 5 MB and can be used on all Control SL products without restrictions.
2302000051
From $167.00
License Control Standard M
Metric
Standard S
Standard M
Standard L
EtherCAT/Profinet/EthernetIP
1 instance
1 instance
2 instance
CANopen/Profibus/Modbus/J1939
4 instances
8 instances
10 instances
Number I/O channels
512
1024
4096
Code size
3 MB
5 MB
6 MB
Visu S
Visu S
Visu S
Communication
Communication S
Communication S
Communication S
DataSource Manager
Yes
Yes
Yes
Dynamic Ansi C code
Yes
Yes
Yes
No
No
Yes
CODESYS Communication
CODESYS Visualization
CODESYS SoftMotion Axes
Description of properties
Trial Operation
License check
Upgrade licenses
Application-based licenses can be combined with other store products, unless explicitly excluded. The I/O channels of additionally purchased fieldbuses are taken into account in the I/O channels license metric and are also counted.
  • Additional libraries are used: 3 MB code of license Basic L allow a lot of additional logic.
  • Additional logic to connect to the cloud: 5 MB code of license Standard M allows a very large application.
  • A lot of logic due to multiple monitoring and cloud connection: 6 MB code of license standard L allow very large applications
  • Mainly use of CODESYS libraries whose code size is not taken into account in the licensing: 3MB code of the Standard S licence is sufficient.
  • CODESYS Control Win SL
  • CODESYS Virtual Control SL
Updates
