CODESYS Control Performance XL
The application-based CODESYS Control Performance XL license is specially designed for applications with the highest performance requirements. The function of pinning task groups to isolated cores enables a significant reduction in task jitter. The license also includes 16 complex fieldbus instances (up to eight as host) and 65535 I/O channels. It can be used on all Control SL products without restrictions.
2302000069
From $1,139.00
License Control Performance XL
Metric
Performance L
Performance XL
Fieldbus instances
16
16
Complex fieldbus instances
8
16
thereof host instances
8
8
8
16
Number of I/O channels
16384
65535
Visu S
Visu S
Communication
Communication S
Communication S
DataSource Manager
Yes
Yes
Dynamic C code
Yes
Yes
Yes
Yes
CODESYS Communication
CODESYS Visualization
CODESYS SoftMotion Axes
Description of properties
Trial Operation
License check
Upgrade licenses
  • CODESYS Control Win SL
  • CODESYS Virtual Control SL
Updates
