CODESYS Control Performance L
The application-based license CODESYS Control Performance L is specially designed for applications with highest performance requirements. The function of pinning task groups to isolated cores enables a significant reduction in task jitter. The license also includes eight Ethernet-based fieldbus instances, 16384 I/O channels and supports an application size of up to 18 MB. It can be used on all Control SL products without restrictions.
2302000054
From $719.00
License Control Performance L
Metric
Performance M
Performance L
EtherCAT/Profinet/EthernetIP
4 instance
8 instances
CANopen/Profibus/Modbus/J1939
12 instances
16 instances
Number I/O channels
8192
16384
Code size
12 MB
18 MB
Visu S
Visu S
Communication
Communication S
Communication S
DataSource Manager
Yes
Yes
Dynamic Ansi C code
Yes
Yes
Yes
Yes
CODESYS Communication
CODESYS Visualization
CODESYS SoftMotion Axes
Description of properties
Trial Operation
License check
Upgrade licenses
Application-based licenses can be combined with other store products, unless explicitly excluded. The I/O channels of additionally purchased fieldbuses are taken into account in the I/O channels license metric and are also counted.
  • Additional libraries are used: 3 MB code of license Basic L allow a lot of additional logic.
  • Additional logic to connect to the cloud: 5 MB code of license Standard M allows a very large application.
  • A lot of logic due to multiple monitoring and cloud connection: 6 MB code of license standard L allow very large applications
  • Mainly use of CODESYS libraries whose code size is not taken into account in the licensing: 3MB code of the Standard S licence is sufficient.
  • CODESYS Control Win SL
  • CODESYS Virtual Control SL
Updates
