With this product 6 axis groups or CNC interpolators can be controlled.
Functional principle
Parameterization of axis groups for predefined kinematics in a separate object
Integrated motion planning:
with 3D CNC editor according to DIN 66025 (G code) and tabular editor
with coordinate values for robot positions in different coordinate systems
Processing of CNC motion, robotic motion, or other motion tasks in the runtime system on the controller with the IEC 61131-3 logic application
Online editing of CNC programs in CODESYS Visualization
Typical applications
CNC motion with modifications by the end user (for example, in metal and woodworking machines)
Robotic systems including SCARA, tripod, and palletizing robots such as in assembly and loading automation
All supported by CODESYS:
Real-time capable operating system platforms
CPU platforms with available FPU (Floating Point Unit)
Devices with integrated fieldbus (EtherCAT, CAN/CANopen)
WIBU Codemeter Support
