Search results for: 'soft control'
- controller+plc 162
- soft codesys 192
- soft and 169
- softplc+license 162
- software codesys 181
MySQL Library SL 2112000006$120.00 As low as $97.20The MySQL Library SL enables a direct connection between a MySQL database and a CODESYS V3 controller application to read and write data – without additional drivers or software on the controller.For more information: https://support.powerio.com/hub/codesys-hvac/mysql-library/descriptionWithout license acquisition (download only), the MySQL Library SL operates for 30 minutes without functional limitations (Demo).Learn More
