Upgrade to CODESYS Control Standard S
Upgrade of an already purchased application-based license (Base License) to the application-based license Standard S. The costs of the already purchased license (Base License) are fully credited.
2302000050
$143.00
This product can be used to upgrade the application-based license installed on the system to the Standard S application-based license.
Application-based license Standard S
A description of the application-based license Standard S can be found here:
https://us.store.codesys.com/en/codesys-control-standard-s-bundle.html
Installation
  • CODESYS Control Win SL
  • DataSource Manager is not supported on Linux-based systems.
