Upgrade to CODESYS Control Standard M
Upgrade of an already purchased application-based license (Base License) to the application-based license Standard M. The costs of the already purchased license (Base License) are fully credited.
2302000051
$167.00
This product can be used to upgrade the application-based license installed on the system to the Standard M application-based license.
Application-based license Standard M
A description of the application-based license Standard M can be found here:
https://us.store.codesys.com/en/codesys-control-standard-m-bundle.html
Installation
  • CODESYS Control Win SL
  • DataSource Manager is not supported on Linux-based systems.
