Upgrade to CODESYS Control Performance L
Upgrade of an already purchased application-based license (Base License) to the application-based license Performance L. The costs of the already purchased license (Base License) are fully credited.
2302000054
$719.00
This product can be used to upgrade the application-based license installed on the system to the Performance L application-based license.
Application-based license Performance L
A description of the application-based license Performance L can be found here:
https://us.store.codesys.com/en/codesys-control-performance-l-bundle.html
Installation
  • CODESYS Control Win SL
  • DataSource Manager is not supported on Linux-based systems.
