Search results for: 'plc's'
CODESYS Automation Server On-Prem 25 2315000020 Subscription$899.00With the CODESYS Automation Server On-Prem 25 license, you connect up to 25 PLCs to your CODESYS Automation Server On-Prem. The license is offered as a one-year subscription and can be booked multiple times to connect additional PLCs.
