BE KOLLMORGEN s300s700 CAN
Single axis motion function blocks for Kollmorgen s300 & s700.
2112000002
$180.00
  • Buy 4 for $171.00 each and save 5%
  • Buy 10 for $163.80 each and save 9%
  • Buy 25 for $153.00 each and save 15%
  • Buy 50 for $145.80 each and save 19%
Single Axis motion function block’s for Kollmorgen s300/s700 drive.
Programming system
CODESYS Development System Version 3.5.0.0 or higher
Supported Operating Systems
All
CANopen interface
Best Engineering
BEST Engineering Scandinavia AB
Sabelgatan 4
SE 25467, HELSINGBORG
SWEDEN
Phone: +46-42-456 45 00
info@best-engineering.net
Best Engineering
Sabelgatan 4
SWEDEN
