The CODESYS PROFINET Controller SL is not compatible with application-based licenses.
CODESYS PROFINET Controller SL is a product that end users can use to implement a PROFINET network with a CODESYS compatible controller.
2303000015
$180.00
PROFINET (Process Field Network) is an open standard for realtime industrial Ethernet systems in automation technology. It is promoted by the user organization PI (PROFIBUS & PROFINET International as an umbrella group of the PROFIBUS user organization PNO) and is regarded as the successor of PROFIBUS. PROFINET uses IEEE 802.3 (Standard Ethernet) based Profinet RT protocol for realtime cyclic IO data exchange and UDP/IP for acyclic services.
The fully integrated CODESYS PROFINET Solution provides a uniform configurator for different variants of underlying PROFINET Controller communication stacks:
  • CODESYS PROFINET Controller (IEC)
    Protocol stack in the form of a CODESYS library (in IEC 61131-3 code), operates on standard network interface cards.
    For CODESYS Control RTE high performance ethernet adapter drivers are available (see requirements).
    The ethernet adapter is not used exclusively, it’s still available for all other applications using TCP/IP on this adapter (e.g. CODESYS Visualisation, Web Browser).
CODESYS PROFINET Configurator
  • configurator for settings of PROFINET Controller
  • configuration of as slaves (single AR to PROFINET field device) with communications settings
  • configuration of device/module specific parameters, in- and output-mapping
  • status page with detailed view of currently pendig diagnostics and previously received alarms
  • scan dialog with device-import function, online/offline compare, I&M data
  • topology configurator (for device exchange, IRT-planning)
  • TCI support
Picture 1: Configuration with validation
Picture 2: Diagnosis in Status Page
Picture 3: Scan Dialog with I&M Functions
Profinet-Stack (IEC)
CODESYS PROFINET Controller Stack in principle can run on any standard ethernet adapter hardware (see requirements and restrictions). This ethernet adapter is still be used for other services like CODESYS Communication (with IDE), Web-Server, or other CODESYS Fieldbuses (except EtherCAT). The CODESYS Runtime and the operating system (e.g. firewall) have to be configured correctly. For details, see CODESYS Online Help / Fieldbus Support (https://help.codesys.com/)
Feature
PROFINET Specification
V2.45
Conformance Class
B
Max. Number of connections
64 (default) - 1024
Max. IO-Data (total)
no limit
Max. IO-Data (per slave)
1440 input and 1440 byte output
Max. acyclic data
16 KB
Plattforms / OS (see restrictions)
Windows, Linux, VxWorks, WinCE
CPU
32/64 Bit
Little-/Big-Endian
Provider-/Consumer-Status
yes
Automatic Name Assignment (Device Exchange)
yes
Topology-Config
yes
Fast Startup
yes
MRP-Configuration
yes
MRP-Role
Client, see Dual Port
Dual Port
yes, see below
Shared Device
yes
Device Access AR
yes
System Redundancy
S2
Dynamic Reconfiguration
yes
Performance
depends on Plattform ( ** see below)
tested with 64 frames / ms
CODESYS PROFINET Controller (IEC) and Dual-Port Interface:
With standard Ethernet Adapter hardware only single port devices are possible, i.e. each PROFINET Controller can handle just one port. (The system itself may have more than one Ethernet adapter, maybe running a PROFINET Device on it).
A Dual-Port Controller (e.g. for MRP support or a ‘daisy-chain’) may be implemented with special dual-port (bridge) Ethernet chipsets, but this requires some runtime adaptions by the OEM.
Performance CODESYS PROFINET Controller (IEC):
The IO performance, i.e. the possible transmitted ethernet frames / ms differs between outstanding (CODESYS Control RTE) and weak (out of the box Win CE).
This depends nearly solely on the CODESYS Runtime’s SysEthernet implementation.
Of course a system that manages only 8 frames / ms can handle for example 32 slaves - but ‘only’ with an update interval of 4 ms.
Examples with 1 ms update rate:
Plattform
Frames / ms
CODESYS Control RTE
64
CODESYS Raspberry Pi SL
8
Programming Interface (API for IEC application)
The PROFINET Controller provides a rich API for Profinet related functions and utilities that can be used by the application at runtime.
Function
Description
DCP-Identify (Bus-Scan)
Function block ProfinetCommon.DCP_Identify
DCP-Set/Get
Function block ProfinetCommon.DCP_Set / DCP_Get
set / get IP-Address or Stationname
Factory Reset
Function block ProfinetCommon.DCP_Reset
IO-Link
- Read / Write IO-Link Parameters with Function block ProfinetCommon.IOL_CALL
- Smart Sensor Profile Support with Function Blocks in ProfinetCommon library
Status Outputs
Implicit Profinet slave function block:
xRunning: Connection established
xError: Connection aborted / failed
xDiagnosis: diagnosis available
xModuleDiff: module configuration not matching (wrong or missing).
Status Outputs Controller
Implicit Profinet Controller function block:
xOnline: Profinet Controller is online
xBusy: Controller is in startup phase
xError: Profinet Controller is in error state
xDataValid: All IO-Data of the configured Profinet devices is valid.
Dynamic connect/abort
Implicit Profinet Controller or slave function block, method SetCommunicationState()
Generic access on device- and module-configuration
Function block ProfinetCommon.DeviceIterator and SubmoduleIterator
Generic API for iterating Slave- or Module Configuration and Status
Diagnosis Shadowing
Function block ProfinetCommon.DiagnosisBuffer
All Diagnosis Data is locally buffered
Receive Alarms
Function block CommFB.RALARM
Acyclic Read/Write
Function block CommFB.RDREC / WRREC
Direct IO-Data access
Function block CommFB.SETIO_PART / GETIO_PART
Device-Access AR
Function block CommFB.CNCT
Reconfigure
Function block DED.Reconfigure
Enable/Disable modules, slaves or the complete Profinet stack
Function block IoDrvProfinetBase.ControllerConfigUtil:
Change configured Stationname, Slot / Subslot oder device-settings in application.
CODESYS Control V3.5.17.0 or higher
CODESYS runtime system with these components
* SysEthernet
* SysSocket
Technical requirements
* Ethernet Adapter (for Control RTE with Intel or Realtek chip)
Legal requirements
A certification by a PI Test Lab is mandatory for every PROFINET Controller or Device that is sold to end-users.
Details on certification can be found here:
www.profibus.com/products/product-certification/
Certification is currently possible for
* Control RTE > V3.5.18.30
* Linux based runtimes > V3.5.17.30
