Search results for: '2304000013 f'
- 2304000013 9
MySQL Library SL 2112000006$85.00 As low as $68.85This Library allows you to connect your CODESYS v3.5 application to a MySQL-Sever database to read and write data from it.
Without purchasing a license (just download) the MySQL Library SL runs for 30 minutes without functional limitations and disconnects automatically (demo).
HVAC KNX SL 2312000023$120.00The HVAC KNX Library enables sending and receiving KNX group addresses via KNX IP interfaces (UDP) directly from the IEC program. It offers ready-made function blocks for various DPT KNX data types and has been tested with various manufacturer-specific KNX IP interfaces.
For more information: https://support.powerio.com/codesys-hvac/hvac-knx-library/description
Without license acquisition (download only), the HVAC KNX SL operates for 30 minutes without functional limitations (Demo).
HVAC Building Automation Package SL 2312000005$110.00 As low as $89.10HVAC (Heating Ventilation and Air-Conditioning) functional components and HTML5 visualisation. Automate and visualise your entire building technology professionally and independently of hardware: ventilation systems, heat generation, heating circuit distribution, individual room control, room automation, light and blind control.
Further information: https://support.powerio.com/codesys-hvac/hvac-library/description
