IEC 60870-5-104 Server
The Telecontrol package contains an IEC 60870-5-104 server that can be fully activated with this license. Without purchasing a license, the IEC 60870-5-104 server SL runs for 30 minutes without any functional restrictions (demo mode).
1.1.4.0
2312000014
$290.00
The Telecontrol package allows to use the CODESYS PLC as IEC 60870-5-104 server. All relevant features of the IEC 60870-5-104 protocol are implemented:
  • See the interoperability list below
  • Library written in IEC61131-3
  • Configurator as CODESYS PlugIn
Range of Functions
  • Support of information objects of this following groups:
    • Monitoring direction: SP, DP, ST, BO, ME, IT
    • Control direction: SC, DC, RC, SE, BO
      For protocoll detailed functionality, see the interoperability list.
  • Telecontrol configurator properties
Note
Check the licensing options of your controller with the free CODESYS Device Reader.
CODESYS Development System V3.5.16.0
Target System
CODESYS Control V3.5.16.0
CODESYS Runtime SL Systems
none
CODESYS Redundancy SL is not supported
Single Device License: The license can be used on the target device/PLC on which the CODESYS Runtime System SL is installed.
Licenses are activated on a software-based license container (soft container), which is permanently connected to the controller.
Alternatively, the license can be stored on a CODESYS Key (USB-Dongle). By replugging the CODESYS Key, the license can be used on any other controller.
Note: In demo mode, the software runs half an hour without a license. After that, the server will be stopped.
Required Accessory
CODESYS Runtime Key or SoftContainer
3S-Systems GmbH
Marienweg 4a
31542 Bad Nenndorf
support@3s-systems.com
3S-Systems GmbH
Marienweg 4a
31542 Bad Nenndorf
Task #209 IEC 60870 Server: ActTerm sent with wrong Common Address of ASDU 22.09.2026
Task #142 Remove obsolete code 17.09.2025
Task #141 CSV import / export throws exception 09.05.2025
Task #132 CDS Plugin: Bugfix ModuleType check 10.10.2024
Task #131 IEC 60870 Server: Raising the system limits 16.04.2024
Task #102 Bugfix Timestamped command objects 18.07.2023
- 21.12.2022
- 24.11.2022
- 25.10.2022
Initial release 04.10.2021
