The CODESYS SoftMotion is not compatible with application-based licenses.
CODESYS SoftMotion
CODESYS SoftMotion is an additional option for CODESYS compatible SoftPLC systems. CODESYS SoftMotion extends the functional scope of these systems from a purely logical controller to a motion controller, optionally also with CNC and robotics support.
4.20.2.0
Bundle-SoftMotion
From $132.00
CODESYS SoftMotion enables the control of single-axis and synchronized multi-axis movements (electronic cams, electronic gears).
CODESYS SoftMotion CNC+Robotics enables the control of CNC machines and industrial robots.
CODESYS SoftMotion Light allows to command CiA 402 compatible drives for single axis movements (not synchronized).
Functional principle:
  • Motion planning with cam editor
  • Integrated motion planning:
Typical applications of CODESYS SoftMotion:
A note on SoftMotion Light: In contrast to SoftMotion and SoftMotion CNC+Robotics, the calculation of the axis movements is not done within the controller. With SoftMotion Light movements of the drive are just commanded and supervised (status) by the PLC and executed by the drive. The trajectory calculation is done in the drive.
SoftMotion Light is suitable for applications with multiple axes for single axes movements and for controller tasks requiring a low bus and computing load (CPU).
CODESYS Control Version 3.5.14.0 or higher
All supported by CODESYS:
WIBU Codemeter Support
SoftMotion CNC+Robotics requires CODESYS SoftMotion as a basis license.
Release Note
This version fixes a critical bug in the SoftMotion axes for EtherCAT drives.
Major Bug-Fixes
  • [SM-6363] CLONE - SM3_Drive_ETC: Division by zero after 2^32 cycles after wCommunicationState 80 has been reached
Compatibility Information
General
This version is compatible with CODESYS V3.5 SP17 and newer. However, it is recommended to use the latest version of CODESYS.
Information from JIRA
List of features and changes:
project = SM AND fixVersion = 4.20.2.0
project = SM AND fixVersion = 4.20.2.0 AND (text ~ COMPATIBILITY_INFORMATION OR text ~ KNOWN_LIMITATIONS)
20.01.2026
Release Note
This version patches a critical bug.
Major Bug-Fixes
  • [SM-6287] CLONE - Axis group: Potential access violation
General
project = SM AND fixVersion = 4.20.1.0
project = SM AND fixVersion = 4.20.1.0 AND (text ~ COMPATIBILITY_INFORMATION OR text ~ KNOWN_LIMITATIONS)
27.11.2025
Release Note
This version adds the G31 command (probing function and clear remaining distance) for CNC, the new TransitionMode TMAxisDistance for Robotics, and some small improvements and bug fixes.
  • [SM-1963] MC_TRANSITION_MODE: new distance based blending mode in axis space
    • [SM-2310] MC_TRANSITION_MODE: new distance based blending mode for pure axis space interpolation
    • [SM-6127] Create an empty kinematic to better support movements when all axes are not mechanically coupled
  • [SM-3903] Create an example project with documentation for SMC_SmoothMerge with a large G-Code file
  • [SM-4896] SM3_CNC: Make it possible to access information about the current state of the interpolator
  • [SM-5208] CNC Preprocessing: Create an example on how to write a customer specific preprocessing function block
  • [SM-5880] CNC: Support for G31 probing function and clear remaining distance
  • [SM-5881] CNC: DryRun (Additional velocity limit for commissioning or debugging)
  • [SM-5912] Cam table: There should be a function for evaluating a cam table
  • [SM-5915] MC_CamIn: Improve documentation
  • [SM-5916] CNC: Create an example for SMC_StringStream2
  • [SM-6077] SMC_FollowSetValues: Option to ignore MC_SetPosition
  • [SM-6135] Basic Motion: Improve error log messages
  • [SM-6154] MC_ReadStatus: Add new output AxisError
  • [SM-6155] Axis group, TransitionParameter: Create functions for setting the TransitionParameter for TMCornerDistance and TMStartVelocity
  • [SM-6165] SMC_OrientationBasedOnTangent: changes to inputs RelativeOrientation and Normal should be applied without new rising edge on Enable
  • [SM-6172] Create example for G31 probing function and clear remaining distance
  • [SM-6176] Axis group: There should be a function for checking whether movements can be accepted
  • [SM-6191] MC_MoveCircularAbsolute, MC_MoveCircularRelative: Do not report an error for zero length circles
  • [SM-6193] EtherCAT_BRC_CtrlXDrive_SoE change the default scaling value
Major Bug-Fixes
  • [SM-6131] MC_GroupSetPosition, Additional Axes: Axis limit violation when using MC_GroupSetPosition between pure additional axes movements
Minor Bug-Fixes
  • [SM-1611] SMC_PreacknowledgeMFunction is not task-safe
  • [SM-4905] Online Monitoring: After an online change the position in axes page is no longer updated
  • [SM-4949] MC_Stop: Misleading error message (FB was not called during motion) when the drive is not in regulation
  • [SM-5926] Licensing: “Demo mode expired.” is logged even if SoftMotion is licensed
  • [SM-5932] GroupJog2: Jogging in ACS with other axes outside of their software limits result in misleading errors
  • [SM-6080] SoftMotion BasicPage: Rename “Position lag supervision” to “Position lag monitoring”
  • [SM-6084] MC_GearIn: Unexpected axis error when Master is turned off
  • [SM-6095] Robotics: Modulo axes might not finish their movement at the specified target position (numerical issues)
  • [SM-6097] SMC_FollowSetValues: bAbort does not reset the owner of the axis
  • [SM-6100] SMC_AXIS_STATE: Wrong documentation
  • [SM-6104] Visu template of SMC_GroupJog2: wrong texts in online mode
  • [SM-6105] Axis Group writes 0 to set torques of all axes even if no dynamic model is configured and the group state is GroupDisabled
  • [SM-6119] Some basic motion FBs do not log all their FB errors and report them to the axis
  • [SM-6138] MC_GroupInterrupt: Movement commanded before the interrupt might be accepted after the interrupt
  • [SM-6150] Axis group: QueueUnderrun not detected/reported properly
  • [SM-6151] Axis Group Editor: Mapping to Axes shows wrong control element in case no mapping exists
  • [SM-6152] MC_Stop does not abort buffered movements, leading to axis error SMC_BLOCKING_MC_STOP_WASNT_CALLED
  • [SM-6169] CNC: SMC_NCInterpreter returns generic error SMC_DEC_INVALID_SYNTAX for many different situations
  • [SM-6170] SMC_NCInterpreter: G-Code ending with an N-Word causes error SMC_PRS_INCOMPLETE_SENTENCE_IN_TOKEN_QUEUE
  • [SM-6174] SMC_GroupSaveContinueData might save inconsistent movement data
  • [SM-6175] SM3_Robotics: Possible endless loop when using kinematics with zero axes
  • [SM-6180] ContinueData, ResumeAfterError: possible wrong add axes continue position is stored
  • [SM-6187] SMC_CP_TRANSITION_NOT_SMOOTH when trying to blend between movements with OrientationMode Axis and GreatCircle without an orientation kinematics
  • [SM-6192] SM_Drive_EtherCAT_SoE_Standard: Error during configuration phase [Probe 2: continuous measuring not supported]
  • [SM-6268] AdditionalAxes: Invalid path element created in special case
General
  • [SM-1619] CNC: SMC_Interpolator2Dir is not task-safe
    Starting with CODESYS SoftMotion 4.20.0.0, the function block SMC_Interpolator2Dir_SlowTask must be called from the same task that reads the G-Code and processes the CNC path.
    Otherwise, errors may happen while reversing on the path with SMC_Interpolator2Dir.
    This is especially important when the tasks are distributed to different CPU cores.
    As of version 4.20.0.0, axis groups do not compute the set torques of their axes when they are disabled. When disabling the axis group, the set torque values of the kinematic axes are set to 0.
    Movement function blocks like MC_MoveLinearAbsolute now might report CommandAccepted one cycle later in the following case: - There are multiple commanded movements that have not yet been accepted (Busy = TRUE AND CommandAccepted = FALSE). This generally only happens if a lot of movements were already buffered and are waiting to be executed. - And the movement FBs are called in a different order than they were originally executed. - And more than one of these movements can be accepted in the same cycle. This requires that more than one preceding movement is Done in the same cycle.
Known Limitations
project = SM AND fixVersion = 4.20.0.0
project = SM AND fixVersion = 4.20.0.0 AND (text ~ COMPATIBILITY_INFORMATION OR text ~ KNOWN_LIMITATIONS)
18.11.2025
Release Note
This version adds support for additional axes to SoftMotion Robotics. Additional axes are axes that are not part of the robot, but are interpolated together with the robot’s axes.
  • [SM-1310] Robotics: Support for additional / auxiliary axes
  • [SM-360] CiA 402 driver: better error message if fTaskCycle cannot be stored in 60C2
  • [SM-2059] Drive editor: There should be some kind of warning if software limits or position lag supervision is enabled but no software error reaction is configured
  • [SM-2407] Position Lag Supervision: Add parameter fSetActTimeLagCycles (Nr. 1070) to configurator
  • [SM-4752] Deprecate Staubli libraries, device descriptions and kinematics after the release of the Staubli package
  • [SM-5537] CamBuilder: It should be possible to create periodic cams using implicit boundaries
  • [SM-5565] Scripting: Enabling/Disabling SoftMotion should be possible via the scripting API
  • [SM-5585] Consider the velocity factor (object 6096) for generic CiA 402 drives
  • [SM-5630] New function blocks SMC_ChangeAxisScalingRotary and SMC_ChangeAxisScalingLinear
  • [SM-5785] SM3_Drive_CiA_DSP402: prefer exponent -3 (ms) when computing task interval in object 60C2
  • [SM-5812] Allow to configure dead time for SMC_GetTravelTime and SMC_DigitalCamSwitch_HighPrecision
  • [SM-5874] Unify and improve documentation of SoftMotion drivers
  • [SM-5883] Integrate support for Kollmorgen KED drive
  • [SM-5886] Add possibility to stay in ‘Ready to Switch On’ and not ‘Switch On Disabled’ for the generic CiA402 driver
  • [SM-5897] GroupReadSetPosition/Velocity/Acceleration/Jerk should support a TimeOffset
  • [SM-5899] CNC: Make it possible to use the kinematics from SM3_Transformation (Robotics)
  • [SM-5901] CNC: Create function block that computes the orientation to be tangential to the path
  • [SM-5903] New SoftMotion Driver for Maxon EPOS4 series
  • [SM-5909] Integrate Danfoss motion Driver Servo Drive ISD 510 in Codesys Softmotion
  • [SM-5920] Create a way to read the cyclically mapped parameters
  • [SM-5943] SM3_Drive_ETC_Beckhoff_EL70xx: Don’t write operation mode at startup, add device description for EP7041-3002
  • [SM-5950] SM3_Drive_CAN_Brunner: Remove deprecated driver from SoftMotion
  • [SM-5954] SM3_Drive_CAN_Nanotec_SMCI47S: Removed deprecated driver from SoftMotion
  • [SM-5958] SM3_Drive_ETC_DANAHERS400S600: Remove deprecated driver from SoftMotion
  • [SM-6065] Kin_Bipod_Rotary and SMC_TRAFO_Bipod_Arm: Support axis angles in the range -180 .. 180 instead of -90 .. 90
  • [SM-6069] SM3_Drive_ETC_Kollmorgen_AKD2G_AKD_MKD: update the Esi Data
Major Bug-Fixes
  • [SM-5840] Robotics: Triggers at the start or end of a movement might not become active
  • [SM-5898] SMC_GroupTargetPosition no longer works for relative movements
  • [SM-5951] Robotics: SMC_ABORTING_INTERNAL_ERROR when aborting with a zero length movement
Minor Bug-Fixes
  • [SM-222] SMC_CamRegister: performance is very bad, refactor duplicate code
  • [SM-801] SM3_Math: Global symbols should have prefix SMC
  • [SM-2201] SM: SMC_CamRegister does not work properly for certain velocity and Tappet Value combinations and if the Tappet action is ‘invert’
  • [SM-5390] SM Light not shown on License Metrics screen
  • [SM-5544] Cam editor, table: Column “Segment Type” is not right aligned
  • [SM-5551] Cam: “Display Generate Code” in Menu is missing
  • [SM-5588] Generic DSP402 driver: Parameter _abyControllerMode is not configurable
  • [SM-5591] MC_AbortTrigger, CiA 402: While aborting, touchprobe is reenabled for one cycle
  • [SM-5596] Finite rotary axes with software limits return a position lag error when moving outside the limits
  • [SM-5602] SMC_ETC_InterpolateAxisPosition cannot be used for encoder axes
  • [SM-5614] Robotics: Some outputs of movement FBs are not reset after being called with Execute=FALSE
  • [SM-5625] SMC_CP_ROTARY_AXIS_PERIOD_MISMATCH after following a moving PCS for some time
  • [SM-5652] MC_GroupInterrupt, SMC_GroupInterruptAt: May report CommandAborted=TRUE after Done=TRUE
  • [SM-5801] Custom kinematics: Unitialized CONFIGDATA variable can cause error SMC_CP_CONFIGS_DIFFER
  • [SM-5811] SMC_ETC_InterpolateAxisPosition and example for high precision digital outputs: SyncOffset is not considered
  • [SM-5815] SMC_TRAFO_Scara3: Parameters dOffsetA/B <> 0 lead to a wrong value for dC
  • [SM-5822] CamBuilder: Implicit right bound of ModifiedSine segment is not correctly resolved if the subsequent segment is a Line
  • [SM-5823] CamBuilder: An error is reported when trying to append a ModifiedSine segment with identical left and right slave position y
  • [SM-5827] VisuCamDisplayer: When changing the displayed cam, the visualization is updated in two steps
  • [SM-5832] SMC_Matrix3_FromRollPitchYaw_deg: Wrong description for the roll and yaw angle
  • [SM-5846] Drive editor: Check if all required parameters exist before changing the movement type
  • [SM-5869] CNC, G4: reverse moving over CNC G4 is not possible
  • [SM-5885] ProjectEnvironment: SoftMotion reports a version change even if the version has already been set to the newest version
  • [SM-5895] ControlTechniques_UniDrive, Panasonic_A6Multi: driver has no documentation
  • [SM-5914] SM3_Drive_ETC_Beckhoff_EL70xx: Problems reading actual velocity and setting the controller mode
  • [SM-5917] SM3_Depictor: DepictorBase library is not referenced via placeholder
  • [SM-5925] SM3_Drive_ETC is not in OnlineHelp
  • [SM-5946] SM3_Drive_ETC_Beckhoff_EL70xx: writing of the feedback type cannot be avoided
  • [SM-5953] SM3_Drive_CAN_INFRANOR_CD1K: Invalid supported drive model in the documentation
  • [SM-5955] SM3_Drive_ETC_Beckhoff_EL70xx: fFactorVel is not correct
  • [SM-6060] SMC_GroupPrepareTrigger: Triggers of type PlaneIntersection lead to an error on zero length movements if the current position lies in the plane
  • [SM-6068] Possible wrong tool offset compensation for coupled kinematics
General
    The device descriptions and kinematic function blocks for Staubli robots based on the old CS8 controllers have been deprecated. They will be removed in a future SoftMotion version.
    The device descriptions and kinematic function blocks for Staubli robots based on the new CS9 controllers have been moved to the new AddOn SoftMotion Staubli Support.
    With previous versions, SMC_ChangeGearingRatio did not check whether the modulo period times the denominator of the scaling ratio was an integer. This could lead to roundoff errors when a modulo axis was moving continuously. This check has now been added. Existing applications that set a scaling ratio for modulo axes may now receive the new error SMC_MODULO_PERIOD_TOO_MANY_DIGITS from SMC_ChangeGearingRatio.
    If software position lag supervision is active, position lags can be reported one cycle later with the new SoftMotion version. The error reaction still happens in the same cycle. It is recommended to test applications using software position lag supervision after updating to the new SoftMotion version.
    For the methods AXIS_REF_SM3_Mapping.IsIncludedInTransmitData and IsIncludedInReceiveData, the type of the parameter data type has been changed from INT to DINT. Drivers may need to be updated. All calls to one of these methods in the driver should be checked as well, casts from DINT_TO_INT can and should be removed.
    The SoftMotion driver for the Beckhoff EL7031, EL7037, EL7041, and EL7047 terminals no longer writes the operation mode (object 0x8012:01) to value 3, position controller, during startup. If this is required for an application, an entry for writing the operation mode can be added to the Startup SDO list of the EtherCAT module.
Known Limitations
project = SM AND fixVersion = 4.19.0.0
project = SM AND fixVersion = 4.19.0.0 AND (text ~ COMPATIBILITY_INFORMATION OR text ~ KNOWN_LIMITATIONS)
02.09.2025
Release Note
This version contains improvements for camming and robotics, as well as various small improvements and bug fixes.
When creating cams, the new segment types modified sine and inclined sine can now be used.
Axis groups now log additional information when an error occurs, and optionally for each movement and command that is executed.
  • [SM-1976] Robotics: more detailed error context
  • [SM-5339] Robotics: Improved logging step 2
    • [SM-4954] Movement IDs should be resolved to the instance path or name of the command FB
    • [SM-4955] Optionally log information messages on path events of the axis group
    • [SM-5275] Robotics: Create detailed error if maximum jerk in first cycle is negative
  • [SM-5359] Cam Improvements step 2
    • [SM-4770] MC_CamIn: Add support for additional cam segment types modified and inclined sine
    • [SM-5018] Cam editor: Add support for cam segment types modified and inclined sine
    • [SM-5442] Create a new visu cam displayer based on the XY Chart
    • [SM-5443] Create a new visu cam editor based on the new cam displayer
  • [SM-109] Use namespace to access elements of CAADeviceDiagnosis library
  • [SM-123] SM: CNC: generate FB that allows to define a path with strings
  • [SM-515] Axis group: CP-Algorithm should support different values for maximum acceleration and deceleration
  • [SM-1154] All drives: quadratic velocity mode should be the default
  • [SM-1517] Add simple kinematic transformation (from SM3_Transformation) to example applications
  • [SM-2441] The SDO timeout for SoftMotion Light axes should be configurable
  • [SM-2702] SoftMotion base driver: automatic restart after fieldbus slave goes back to operational
  • [SM-2865] CNC-Visu SMC_PathCopierFile: Improve FB to support large CNC files
  • [SM-3378] Softmotion Ethercat drives: Not all drives’ ETCSlave can be reached via device diagnostic
  • [SM-4060] AcyclicCom: The SDO should be reset directly during a reinit of the drive
  • [SM-4697] Beckhoff EL7201: Add the steps to configure the motor parameters in the drive documentation
  • [SM-4780] SM3_Drive_ETC_SoE_Standard: use the same fair mechanism for acyclic communication as used for CoE
  • [SM-5113] Improve usability of the cam editor
  • [SM-5153] SM3_Robotics_Visu: Remove reference to CAA Behaviour Model
  • [SM-5280] Generic CiA 402 driver (EtherCAT and CAN): add support for bit 2,3 and 10,11 of touch probe function
  • [SM-5349] AXIS_REF_SM3: consider bus bandwidth when converting from user units to increments
  • [SM-5373] Remove outdated and redundant CHM-based Online Help from AddOn package
  • [SM-5392] Update example projects to SM 4.18.0.0
  • [SM-5404] Document the trigger time more precisely
  • [SM-5417] SM3_Drive_ETC_BRC_CtrlXDrive_CoE: update firmware to Bosch_Rexroth_AG_crtlX_DRIVE_EtherCAT_CoE_20240301
  • [SM-5418] SM3_Drive_ETC_BRC_CtrlXDrive_SoE: update firmware to Bosch_Rexroth_AG_crtlX_DRIVE_EtherCAT_SoE_20240301
  • [SM-5419] SMC_ETC_InterpolateAxisPosition: add time delay functionality
  • [SM-5422] SMC_DigitalCamSwitch_HighPrecision: support forecast and subcycle accuracy
  • [SM-5423] Create example for how to use SMC_DigitalForecast_HighPrecision
  • [SM-5424] AXIS_REF_SM3: automatically initialize the axis after it has been enabled using reconfigure
  • [SM-5448] SMC_SetCustomRampTypes: Deprecate custom ramp types
  • [SM-5457] MC_Home: reset mapping from user units to increments so that position 0 user units corresponds to 0 increments
  • [SM-5465] MC_TouchProbe: new output Active that indicates that rising edges on the trigger input are detected
  • [SM-5472] CNC: allow for more than 512 subprograms, larger expressions in the G-Code, a deeper call nesting, and a larger number of local variables and subprogram parameters
  • [SM-5485] SMC_StartupDrive: Set the default value of MC_Power.Enable to FALSE
  • [SM-5487] SMC_VisuCamEditor: Synchronization between bus and visu task
  • [SM-5490] Create an example on how to use custom G-code functions
  • [SM-5495] SMC3_PersistPositionSingleturn: allow encoder ranges that are not a power of 2
  • [SM-5512] SM3_Drive_ETC_KeDrive_D3: update KEBA_D3xx.xml ESI data
  • [SM-5513] SM3_Drive_ETC_Mitsubishi_MelServo: update Esi data
  • [SM-5514] SM3_Drive_ETC_Kollmorgen_AKD2G_AKD_MKD: update the Esi Data AKD2G-SPE-02-14-00-000.xml
  • [SM-5520] Improve moving cam points in the cam graph editor
  • [SM-5521] Create example project for ReadNCFile2 with token modifiers
  • [SM-5524] Improve diagnostics of mapping editor
  • [SM-5526] Axis group: Aborting in the direction of the current movement should work without reversal
  • [SM-5534] SM3_Drive_ETC_Beckhoff_EL70xx: device description for EL7037 is missing
  • [SM-5538] Disallow assignment of AXIS_REF_SM3 objects
  • [SM-5561] SMC_ETC_InterpolateAxisPosition: support for 32 Bit EtherCAT timestamps
  • [SM-5571] SMC_MoveContinuousAbsolute, SMC_MoveContinuousRelative: Improve documentation for EndVelocityDirection = MC_DIRECTION.current
  • [SM-5579] New SoftMotion Driver for BoschRexroth CtrlXDrive SoE
Major Bug-Fixes
  • [SM-5045] SM3_Drive_ETC_BRC_CtrlXDrive_CoE: jump in position if maximum travel range in drive is not 2^32
  • [SM-5389] Exception when using MC_MoveAbsolute
  • [SM-5408] SMC_TRAFO_Polar, SMC_TRAFO_Scara2, SMC_TRAFO_Scara3: Invalid conversion from rad to degree
  • [SM-5451] SM3_Drive_ETC_SoE_Standard: possible jump in set position at the start of SMC3_ReinitDrive for modulo axes
  • [SM-5515] MC_CamIn: SMC_CI_MASTER_OUT_OF_SCALE after using MC_SetPosition
  • [SM-5531] SMC_FreeEncoder (and other encoder axes): Master/Slave FBs are not working with an encoder as the master
  • [SM-5563] BasicMotion, Blending: No error is reported if the execution order is wrong
  • [SM-5613] Axis group: Jump in torque when a movement starts after a load has been attached while waiting
  • [SM-5629] IDE freezes when editing a Cams tappet table and then switching to another tab
  • [SM-5643] Jump in axis position after SMC3_ReinitDrive
Minor Bug-Fixes
  • [SM-117] In some cases, a value is read by SDO although the underlying object is mapped by PDO (e.g. MC_ReadActualTorque)
  • [SM-1838] SMC_ReadNCFile2 ‘bBusy’ Bit active after error
  • [SM-2216] MC_MoveSuperImposed: Jump in position if MC_MoveSuperImposed is restarted while active and there is no underlying movement
  • [SM-3213] SM3_Drive_ETC_SoE_Standard: Wrong use of AXIS_REF_ETC_SM3 leads to compile errors
  • [SM-3529] Cam Editor: Unintentional change of segment type (Line, Poly5) in Cam table
  • [SM-3973] SMC_NCInterpreter/SMC_Decoder: bAppend=TRUE is not working correctly
  • [SM-4155] SMC_GCodeViewer does not work with sub programs
  • [SM-4493] Robotics: if more than 16 axis groups are used in the same task, no planning calls are done
  • [SM-4624] AutoMoveGantry Tracking: Path deviation too high caused by wrong planner time
  • [SM-4920] CNC Editor: Wrong error message for Ellipse (G8, G9) with invalid value of R
  • [SM-4926] MC_GearIn: possible verlocity overshoot when using ramp type quadratic smooth
  • [SM-4928] Nanotec PD4C: actual velocity differs considerably from the set velocity
  • [SM-4950] SMC_SmoothPath,SMC_RoundPath: bExecute=FALSE does not reset the outputs when an error has occured
  • [SM-4951] SM3_Depictor: SMC_Depictor_Bipod_Arm: invalid expressions
  • [SM-4966] SMC_GEOINFO: Fix wrong comment of piStartPos
  • [SM-5006] SMC_Interpolator: The output vecActTangent is not updated after switching from IPO_INIT to IPO_CONSTANT
  • [SM-5079] Software position lag error reaction does not work
  • [SM-5109] CNC-Editor: Warning C0564 with compile mode SMC_CNC_REF and variables in G-Code
  • [SM-5201] SMC_TrackSetValues and SMC_TrackAxis don’t support override on the controlled axis
  • [SM-5207] AXIS_REF_POSCONTROL: No error is reported when the dead time compensation exceeds 20 cycles
  • [SM-5218] MC_MoveAdditive, MC_SetPosition: MC_MoveAdditive moves to the wrong position if MC_SetPosition is called while the preceding movement is active
  • [SM-5263] SMC_CamRegister: EndOfProfile evaluation is not correct
  • [SM-5344] SMC_SolveTwoRotJoints: Fix typo in documentation
  • [SM-5346] SMC_SmoothPath/SMC_RoundPath and SMC_ToolRadiusCorr cannot be used together, as both use the D-word
  • [SM-5355] SMC_ControlAxisByPos: Position jump if bAvoidGaps is set and active and the iStatus is changed to IPO_INIT or IPO_UNKNOWN
  • [SM-5356] Cam-Editor: Compile format “XYVA”: changing an existing cam segment to Poly7 does not change compile format to “generic segments”
  • [SM-5357] SMC_DisplayNCCallStack: the main program name is wrong
  • [SM-5367] SMC_SmoothMerge: When changing direction a spline with infinite curvature can be created
  • [SM-5371] SMC_CamRegister: The dead time compensation is not correctly converted to cam units
  • [SM-5386] SMC_SmoothMerge: Missing variable initialization leads to failed merge attempts
  • [SM-5391] SMC_NCInterpreter with SMC_GCodeViewer: DYNCALL sentences might be displayed more than once in the SMC_GCodeViewer
  • [SM-5393] SM3_Drive_ETC_Yaskawa_Sigma7: MC_Home may fail due to limited range of home offset (0x607C:00)
  • [SM-5396] AXIS_REF_ETC_BASE_SM3, AXIS_REF_CAN_SM3: rework resetting errors during startup
  • [SM-5399] Kin_Bipod_Rotary: AxesToCartesian might return without setting outputs
  • [SM-5402] AXIS_REF_SM3: SMC3_ReinitDrive not working if the slave device has been disabled at startup
  • [SM-5405] MC_Reset aborts all movements even if there is no error to be reset
  • [SM-5409] Motion Devdescs: The motion devdescs are outdated and have no Devdiag instance.
  • [SM-5420] MC_CamIn reports CommandAborted if the Master is already moving and updated after MC_CamIn
  • [SM-5431] SM3_Drive_ETC_SoE_Standard: bStartReferenceRealState is not TRUE during homing
  • [SM-5432] SM3_Drive_ETC_SoE_Standard: MC_TouchProbe not working
  • [SM-5434] SMC_Drive_ETC_Schneider_Lexium32: problems with limit switches with latest firmware
  • [SM-5435] Cam Editor: Undo/Redo not working when changing the segment type in the cam table view
  • [SM-5436] Cam Editor: Sometimes changing the segment type does not work on the first try
  • [SM-5441] MC_MoveAbsolute/Relative: Error SMC_MOVING_WITHOUT_ACTIVE_MOVEMENT reported when using trapezoid or sinsquare velocity profile and extremely high Deceleration
  • [SM-5454] Cam Editor: Jerk boundaries keep their values after switching from Poly7 to Poly5
  • [SM-5456] SM3_Drive_ETC_Yaskawa_Sigma7: limit switch handling not robust if digital inputs (60FD) are mapped or multi-axis devices are used
  • [SM-5467] SM3_Drive_CAN_KEB_SD, SM3_Drive_ETC_Panasonic_MINAS_A6B: Wrong placeholder in Project Information
  • [SM-5473] SM3_Drive_ETC_SoE_Standard: timeout for configuration phase can cause problem if many slaves are used
  • [SM-5474] CiA 402 based drivers: timeout for configuration phase can cause problem if many slaves are used
  • [SM-5476] Kin_Staubli_TX60_S1_R4: Wrong machine coordinate system origin
  • [SM-5477] Acyclic communication: acyclic commands are not aborted properly in certain scenarios
  • [SM-5499] CamEditor: Segment and points might not be selectable in the Velocity/Acceleration/Jerk view in the cam graph tab
  • [SM-5505] SMC_ReadNCFile2 uses internal constant for input array sizes
  • [SM-5507] SMC3_PersistPositionSingleturn: potentially wrong position for modulo axes after turning the drive off and on
  • [SM-5530] SMC_FB_WASNT_CALLED_DURING_MOTION is reported for a slave axis when a super-imposed movement is commanded on the master axis
  • [SM-5532] SMC_SmoothAddAxes might get stuck on G75
  • [SM-5540] Cam Editor: the split container heights shrink when closing and reopen the cam editor
  • [SM-5548] Cam Editor: it is not possible to enter integer values in scientific notation
  • [SM-5570] BasicMotion: Some movement function blocks no longer log their instance path when an error occurs
  • [SM-5576] CNC,SMC_SmoothAddAxes: SMC_SAA_SMOOTHAREA_TOO_LARGE” when using G71-G70 commands with G75
  • [SM-5587] SoftMotion: Cut & Paste of whole controller device adds unexpected object to device tree
  • [SM-5611] SMC_GCodeViewer: the value of expressions of type STRING is not displayed
  • [SM-5644] Errors in description of SMC3_PersistPosition and SMC3_PersistPositionSingleturn
  • [SM-5646] SMC_SmoothMerge: A G0 element should not be converted to a line after a merging block
General
This version is compatible with CODESYS V3.5 SP17 and newer. However we recommend the latest version of CODESYS.
    Before SoftMotion 4.18.0.0 it was not possible to have different values for the Acceleration and Deceleration limits: * The minimum of the configured Acceleration/Deceleration was used for both the path Acceleration and Deceleration of Continuous Path movements (MC_MoveLinear…/MC_MoveCircular…). * The configured Acceleration was used both for the axis Acceleration and Deceleration limit. The Deceleration was ignored.
    Starting with SoftMotion 4.18.0.0, different values for Acceleration and Deceleration are supported, both for path and axis limits.
    Applications that were created before SoftMotion 4.18.0.0 may behave differently after an update to SoftMotion 4.18.0.0 if they have movements with different values for Acceleration and Deceleration.
    With CODESYS SoftMotion 4.18.0.0, the behavior of SoftMotion axes after a loss of communication to the servo drive has changed. Now, an automatic reinitialization is performed as soon as the communication is established again. Before, an explicit call to SMC3_ReinitDrive had to be performed. An example for a loss of communication is that the cable to one of the drives is unplugged. The function block SMC_AxisChangeSettings can be used to restore the old behavior, setting the parameter bAutoRestart to FALSE.
    The function blocks SMC_NCInterpreter and SMC_NCDecoder now return the new error SMC_CNC_APPEND_ON_FIRST_RISING_EDGE if bAppend = TRUE on the first rising edge of bExecute. In previous versions, this usage was not handled correctly and would lead to incomplete initialization.
    The input SMC_GCodeViewer.iActObjectSourceNo has been replaced by the new input interpolatedObjectId. All CNC applications using SMC_GCodeViewer need to be adapted to assign the new input instead of the old one. A new output SMC_Interpolator.actObjectId has been added. Existing calls of the form gcodeViewer(iActObjectSourceNo := interpolator.iActObjectSourceNo, …) have to be changed to gcodeViewer(interpolatedObjectId:= interpolator.actObjectId, …).
    SMC_TrackSetValues and SMC_TrackAxis now support an override on the controlled axis. The override will be applied to the Velocity, Acceleration, Deceleration, and Jerk inputs of the function blocks.
    Existing applications where one of the two function blocks was used on an axis that had an active override will now behave differently.
    The dead time (parameter D) has an allowed range of [1..20] cycles. Before SoftMotion version 4.18.0.0, the dead time was implicitly limited to this range. Starting with SoftMotion version 4.18.0.0, an error is reported, both in the editor and by axis during runtime, if the dead time is outside the allowed range.
    The internal variable AXIS_REF_SM3.dwBusBandwidth has been removed. A new internal variable AXIS_REF_SM3.usiBusBitWidth has been added. Applications using public POUs are not affected by the change.
    MC_Reset now waits until an ongoing error reaction of the SoftMotion axis is finished before switching from errorstop to standstill and returning Done. This means that the axis will first decelerate to standstill before the reset finishes.
    For some SoftMotion slave devices, a separate FB instance of the slave device called “<slave device name>_diag” was generated that had to be used for device diagnosis. After updating such devices to version >= 4.18.0.0, this separate FB instance is no longer generated. Instead, the FB instance called <slave device name> can be used for device diagnosis, too.
    With SoftMotion 4.18.0.0, the fact that the slave device is disabled during initialization of the SoftMotion axis no longer leads to an error. Instead, the initialization is stopped until the slave device is enabled. As soon as the device is enabled, the initialization of the SoftMotion axis resumes automatically. Using SMC3_ReinitDrive is no longer necessary after enabling the slave device.
    The function block SMC_SetCustomRampTypes has been marked as obsolete. It will be removed in a future version. Please note that the functionality of custom ramp types had already been removed with SoftMotion 4.11.0.0.
    When executing MC_Home, the mapping from user units to increments will be reset so that after homing, 0 increments correspond to 0 user units. All possible offsets that stem from modulo handling, 32-bit overflow handling, or calling MC_SetPosition, are reset.
    The default value of the Enable input of the MC_Power instance in SMC_StartupDrive has been changed to FALSE (before TRUE).
    The behavior of encoder axes such as FREE_ENCODER_REF has changed in case MC_Power is called on the encoder axis. (Calling MC_Power on an encoder axis is not necessary.)
    Previously, function blocks like MC_CamIn, MC_GearIn, MC_GearInPos, or MC_Phasing used the set position of the encoder axis if MC_Power was called. If MC_Power was not called, they used the actual position. The set position was computed based on the actual position and velocity with a dead-time compensation.
    The new behavior is that the actual position is always used, regardless of whether MC_Power is called. If dead-time compensation is required, a logical axis below the encoder axis can be used.
    The axis state of an encoder axis now is always “standstill”.
    The set position of encoder axes should not be used.
    When instantiating SMC_Virtual_Axis, SMC_FreeEncoder, or SMC_Logical_Axis inside a function block, the compiler attribute ‘no_assign’ has to be added to this function block to avoid a warning.
    If the execution order of the two movement FBs involved in the blending is wrong, the error code SMC_FB_WASNT_CALLED_DURING_MOTION (i.e. the second movement FB was not called after the first one was Done) is now reported. In addition, the instance path of the movement FB that was not called is now logged.
Known Limitations
project = SM AND fixVersion = 4.18.0.0
project = SM AND fixVersion = 4.18.0.0 AND (text ~ COMPATIBILITY_INFORMATION OR text ~ KNOWN_LIMITATIONS)
11.04.2025
Release Note
This version contains improvements to MC_CamIn and forecast functionality for single axis and master/slave movements.
New cam features include distance based ramping in, the segment type Poly7, and a CamBuilder API to programmatically create Cams.
The forecast functionality provides a forecast of the axis movement with high resolution timing. That means you can execute an action a given time (e.g. 100 ms) before an axis reaches a given position. And you can query the position, velocity, acceleration, and jerk that an axis will have at a given time.
  • [SM-4911] MC_CamIn: Additional functionality
    • [SM-4771] Cam: Extend the IEC interface for creating cams
    • [SM-4772] MC_CamIn: Add distance based ramping in
    • [SM-4976] Support for new Cam segment type Poly7
    • [SM-5008] Create an example application for the new IEC cam creation interface
    • [SM-5015] Create an example application for distance based ramp in
  • [SM-5089] Basic motion: Support for forecast
    • [SM-5101] Forecast: function block for querying the duration until an axis position is reached
    • [SM-5102] Forecast for single axis movements: Create example application
    • [SM-5139] Create function block to query the dynamic of an axis in the future
    • [SM-5210] Create function blocks to set and read the forecast
    • [SM-5214] Create function block to query the duration until an axis position is reached
  • [SM-4421] Create examples for the Multi-Axis Function Blocks that are not used for Cams
  • [SM-4626] [Product discontinuation] [Remove Product from Setup] SoftMotion sercos driver
  • [SM-4724] SMC_GroupReadPathDynamics: Create separate POUs for velocity and acceleration to reduce the computation time
  • [SM-4743] Visu libs should be optional libraries
  • [SM-4783] SM3_Drive_ETC: In case of lost sync error, log maximum task jitter and dc sync values
  • [SM-4795] SMC_TRAFO_Tripod_Arm: Improve documentation for inputs
  • [SM-4934] Improve restart behaviour with the sinsquare velocity profile
  • [SM-4939] Create a function block to compute the axis position given a high resolution timestamp (intra-cycle)
  • [SM-4998] Improve performance of SM3_Shared.fmod
  • [SM-5000] MC_CamIn: Document behaviour when starting a cam relatively with a start position <> 0
  • [SM-5020] Implement MC_HaltSuperimposed
  • [SM-5024] MC_SetOverride: improve documentation with diagrams
  • [SM-5044] MC_CamIn, ramp_in_dist: Handle changed or modified cam tables
  • [SM-5058] MC_CamIn: Remove bChangedOnline functionality
  • [SM-5081] Additional segment types: Moved constants gc_SMC_FILE_MAXCAMEL and gc_SMC_FILE_MAXCAMTAP
  • [SM-5105] SMC_GroupWait: improve documentation
  • [SM-5154] MC_CamIn: Add support for BufferModes
  • [SM-5156] BoschRexroth CtrlX Drive: delete old ESI files
  • [SM-5157] CMZ SBD Drive CAN: update the “TransmissionType” in the device descriptions.
  • [SM-5158] New SoftMotion Driver for Mitsubishi Melservo series
  • [SM-5178] Kollmorgen AKD2G: Update device descriptions - new ESI Data
  • [SM-5234] SoftMotion profiles should support relative paths
Major Bug-Fixes
  • [SM-4825] MC_CamIn: Slave position jump when changing cam
  • [SM-4984] Access violation when using MC_GroupReset or MC_GroupDisable
  • [SM-5118] MC_MoveAdditive, MC_MoveSuperImposed, MC_SetOverride: Jump in position when changing the override while MC_MoveAdditive and MC_MoveSuperImposed are active
  • [SM-5119] MC_MoveSuperImposed, Blending: Commanding a blending movement while MC_MoveSuperImposed is active can lead to a huge position overshoot
  • [SM-5203] SMC_TrackSetValues and SMC_TrackAxis: access violation if controlled axis has ramp type sinsquare and quadratic_smooth
  • [SM-5206] MC_GearInPos: Position jump when switching to InSync while an MC_MoveSuperImposed is active on the slave axis
  • [SM-5225] Robotics: possible access violation in planner when using a dynamic model
  • [SM-5269] AxisGroup can get stuck when MC_GroupEnable is called directly after MC_GroupDisable
Minor Bug-Fixes
  • [SM-2055] MC_Halt must not be able to abort homing
  • [SM-3467] Setting a variable mapping to a bit in the EtherCAT I/O mapping leads to a runtime error
  • [SM-4617] SMC_TRAFOF_Scara2/3, SMC_TRAFOF_Polar, SMC_TrafoF_ArticulatedRobot_6DOF: Division by zero exception for invalid parameter values
  • [SM-4751] SMC_Interpolator: Error due too high Spline curvature
  • [SM-4785] SMC_ToolRadiusCorr/SMC_AvoidLoop does not report an error for unsupported ellipses types (G8/9)
  • [SM-4792] MC_CamIn: Acceleration jump after ramping in with sinsquare velocity profile
  • [SM-4897] MC_CamIn: Division by zero when the MasterScaling is set to zero
  • [SM-4899] MC_GearInPos cannot be aborted by MC_Stop while it is waiting for the master axis to reach the MasterStartDistance
  • [SM-4948] MC_Home: Falling Execute edge causes a reset of the POU even when it is not finished yet
  • [SM-5010] MC_CamIn: ramping in may take longer than necessary with velocity ramp type quadratic_smooth
  • [SM-5011] SMC_ToolRadiusCorr, G02: Correction does not work on full circles
  • [SM-5026] MC_CamIn: StartMode = relative is not considered
  • [SM-5051] Tab: Scaling/Mapping: “Auto mapping” does not work correctly if several Devices are present
  • [SM-5059] MC_GearInPos, MC_CamIn: Outputs are not correct when aborted
  • [SM-5084] MC_CamIn: problems when MC_CamIn is followed by a buffered movement
  • [SM-5117] MC_MoveAbsolute/Relative: Wrong axis state while blending
  • [SM-5127] SM3_Drive_ETC_Yaskawa_Sigma7: device description is missing support for velocity offset (0x60B1:00)
  • [SM-5141] MC_MoveSuperImposed, Buffered movements: Inconsistent behavior when using MoveSuperImposed while buffered movements are active
  • [SM-5151] MC_CamIn: Position jump when MC_SetPosition is called on the master axis during camming
  • [SM-5180] Robotics Dynamic model example: Center of mass for the z-axis and spatial inertia for thin rods is not correct
  • [SM-5192] MC_Phasing: Invalid error codes may be returned
  • [SM-5202] SMC_TrackSetValues and SMC_TrackAxis don’t work well with superimposed movement on the controlled axis
  • [SM-5205] MC_MoveVelocity: Jump in position when the function block is not called when it is aborted and the override changes in the meantime
  • [SM-5213] MC_PositionProfile, MC_VelocityProfile, MC_AccelerationProfile: Position is not set correctly for modulo axes
  • [SM-5215] MC_MoveSuperImposed, MC_SetOverride: Effective distance of superimposed movement changes if the override is changed while there is no underlying movement
  • [SM-5230] SMC_AvoidLoop: circle is cut although there is no loop
  • [SM-5242] CAN_Schneider_Lexium32: Wrong attribute value for offlineaccess
  • [SM-5257] SMC_AvoidLoop: full circle is cut due to numerical reasons
  • [SM-5262] SMC_TrackSetValues, SMC_TrackAxis: MC_SetPosition is not handled correctly
General
This version is compatible with CODESYS V3.5 SP17 and newer. However we recommend the latest patch level of CODESYS V3.5 SP20.
    The driver SM3_Drive_sIII_Standard has been dicontinued and has been removed from CODESYS SoftMotion.
    Ellipses (G08/G09) are not supported during active tool radius correction and/or loop avoidance. Starting with version 4.17.0.0, an error is reported for ellipses during active tool radius correction and/or loop avoidance.
    The interruption behaviour of velocity ramp type sinsquare has been changed. If a movement is interrupted while the acceleration of the axis is non-zero, the new movement starts immediately with acceleration 0.
    Previously, the acceleration has first been ramped down to 0 with the configured maximum jerk. This was potentially dangerous, if a small value for the maximum jerk has been configured accidentally. In this case, a large position overshoot could occur.
    The new behavior is thus safer. However, the acceleration now will jump to zero on interruption.
    To activate the old behavior (acceleration ramp to zero) again, you can use the compiler define SM3_BASIC_SINSQUARE_ACC_RAMP in your application.
    A new error “SMC_SUPERIMPOSED_FB_WASNT_CALLED” has been introduced. This error is generated if an MC_MoveSuperimposed or MC_HaltSuperimposed is still active but not called in the current task cycle. The axis changes to errorstop. It is possible, though unlikely, that this error occurs with existing projects that worked without errors with earlier versions of CODESYS SoftMotion. In this case, the application has to be modified so that MC_MoveSuperimposed is called as long as it is active.
    If the input CamTableId is changed while ramping in with StartMode ramp_in, ramp_in_neg, or ramp_in_pos, ramping in is not aborted. If the new cam table evaluates to the same slave state for the given master state as the old cam table, no jump occurs.
    The global variable list SMC_File_Constants of the library SM3_Basic has been deleted. The constants gc_SMC_FILE_MAXCAMEL and gc_SMC_FILE_MAXCAMTAP have been converted into library parameters and moved to the global variable list LibParams.
    Starting with SoftMotion version 4.17.0.0 the behavior when using superimposed movement together with buffered or blending discrete movements is as follows:
    • The trajectories of superimposed movements and the underlying movements do not affect each other. The total distance travelled by the axis is the distance of all superimposed movements plus the distance of all underlying movements.
    • The total superimposed distance will not be reset by any non-aborting movement.
    • In particular, the target position of buffered or blending absolute movements will be the commanded position plus the total superimposed distance.
    • The total superimposed distance is reset when an aborting movement is commanded. An aborting absolute movement will reach the commanded position exactly. The distance travelled by any preceding superimposed movement is not added to the commanded position.
    Fixed with SM-5089.
    Starting with SoftMotion 4.17.0.0, the entry “SoftMotion Profiles” in RepositoryLocations.ini can optionally be a relative path. Previously, only absolute paths were supported.
    SMC_TrackSetValues now behaves like SMC_FollowSetValues if the provided set values can be followed exactly. In particular, the fSetPosition is now expected to be provided in the coordinate system that was active on the rising edge of bExecute. If the coordinate system is changed using MC_SetPosition and the fSetPosition should be provided in the new coordinate system, SMC_FollowSetValues has to be restarted.
project = “CODESYS SoftMotion” AND fixVersion = 4.17.0.0
project = “CODESYS SoftMotion” AND fixVersion = 4.17.0.0 AND (text ~ COMPATIBILITY_INFORMATION OR text ~ KNOWN_LIMITATIONS)
30.07.2024
Release Note
CODESYS SoftMotion 4.16.0.0 introduces override functionality for single axis function blocks in the form of the function block MC_SetOverride. In addition, there are new examples for interrupt/continue and override and numerous small improvements and bug fixes.
  • [SM-137] Create function block MC_SetOverride
  • [SM-3442] Improve documentation for table units in Cam tables
  • [SM-4116] Explain the parameter fPlanningInterval of SMC_TuneCPKernel in more detail
  • [SM-4355] SMC_XInterpolator: support intersection of helix with arbitrary planes
  • [SM-4444] Documentation: Create an example for Interrupt and Continue
  • [SM-4587] Updating the SoftMotion profile should remove any placeholder redirections for SoftMotion libraries
  • [SM-4622] Change Company and Author of SoftMotion libraries in SoftMotion profile
  • [SM-4656] Reduce the memory usage of the axis group by reducing the evaluation cache size
  • [SM-4658] SM3_Transformation: Document position and orientation of the flange frame for all kinematics
  • [SM-4704] Update company, vendor, and author for modified SoftMotion libraries and device descriptions
  • [SM-4822] Fix touch probe Problem for CMZ SBD COE
Major Bug-Fixes
  • [SM-4678] Axis group: Potential FPU invalid operation exception
  • [SM-4725] Axis group, Trigger: Trigger on asymmetric blending elements are projected to an unexpected position
  • [SM-4727] Triggers are not saved in the continue data after MC_GroupHalt with ClearMovements=FALSE
  • [SM-4731] CNC: Unhandled exception when using Interface Language Chinese and ‘Analyze dynamics’ in CNC editor
  • [SM-4793] MC_CamIn: Ramping in starts with a positive acceleration if the slave axis is accelerating in negative direction
Minor Bug-Fixes
  • [SM-3979] SMC_MoveContinuousAbsolute/Relative: AdaptEndVelToAvoidOvershoot does not work correctly with trapezoidal velocity profile
  • [SM-4481] Multi axis slave: Invalid mapping when deleting the address of an object from the second or higher axes and activating automatic mapping afterwards
  • [SM-4554] SM3_Depictor: error when using SMC_R_Depictor_Gantry3 with SMC_R_Depictor_Wrist2
  • [SM-4584] Tracking: Rotary axis jumps into a different period after MC_GroupContinue
  • [SM-4592] SMC_CP_TRAJECTORY_NOT_SMOOTH while jogging
  • [SM-4612] MC_CamTableSelect: The checks for non-equidistant point tables do not use the correct offset and scale
  • [SM-4627] AXIS_REF_SM3: wrong parameter number for fSetTorque in documentation (1153 instead of 1160)
  • [SM-4636] SMC_CamRegister: Documentation is unclear
  • [SM-4650] FREE_ENCODER_REF: there is no input to pass the information that the position in increments is valid
  • [SM-4684] SM3_Drive_ETC: Multiple device descriptions have the wrong parameter number for diActTorque
  • [SM-4691] SMC_MoveContinuousAbsolute, SMC_MoveContinuousRelative: Possible jump in fSetPosition after homing
  • [SM-4695] MC_MoveSuperimposed: Restarting the FB multiple times while it is Busy leads to a wrong Distance
  • [SM-4699] SMC_MoveContinuousAbsolute/Relative: Unexpected reversal when restarting the FB
  • [SM-4720] Misleading documentation for MC_ReadAxisError and TRIGGER_REF
  • [SM-4744] SMC_GetCamSlaveSetPosition: not all errors are reported
  • [SM-4766] MC_SetPosition: documentation contains typo and is unclear
  • [SM-4767] Triggers with errors get enabled after a continue
  • [SM-4768] Trigger: A trigger with an error that is projected to a blending loses the error condition
  • [SM-4778] SMC_Interpolator: Internal error when computing the quadratic velocity profile
  • [SM-4779] SM3_Drive_ETC_SoE_Standard: errors of IDNRead/Write commands are not properly propagated and logged
  • [SM-4796] SMC_MoveContinuousAbsolute, SMC_MoveContinuousRelative: Position jump when used in combination with MC_MoveSuperImposed
  • [SM-4797] SMC_GroupInterruptAt: Pause positions on asymmetric blending elements are projected to an unexpected position
  • [SM-4801] Kollmorgen AKD, AKD2G: SoftMotion drives have the same Device ID
  • [SM-4819] SMC_TRAFO_Tripod_Arm: dMaxAngleBallJoint is not checked correctly
  • [SM-4828] SM_Drive_PosControl: Typo in the DevDesc
General
This version is compatible with CODESYS V3.5 SP17 and newer. However we recommend the latest patch level of CODESYS V3.5 SP19.
    The projection of triggers when blending has been improved. Triggers are now projected to the point on the blending element that is closest to the original trigger point.
    Updating an “AKD EtherCAT Drive (CoE) SoftMotion” slave from a version < 4.16.0.0 to a version >= 4.16.0.0 does not automatically update the SoftMotion Drive below the slave. The drive must be manually updated, e.g. by using the “Update device” dialog.
project = “CODESYS SoftMotion” AND fixVersion = 4.16.0.0
project = “CODESYS SoftMotion” AND fixVersion = 4.16.0.0 AND (text ~ COMPATIBILITY_INFORMATION OR text ~ KNOWN_LIMITATIONS)
15.12.2023
Release Note
CODESYS SoftMotion 4.15.0.0 adds support for trigger points on the path to Robotics, similar to h-functions in our CNC product. Trigger points can be created for movements using a relative position, an absolute distance, or the intersection with a plane. Within a configurable forecast-duration, the trigger can be queried in advance. The precise remaining duration until the trigger is reached is reported.
  • [SM-1328] Robotics: Support digital switches on the path
  • [SM-70] SM: MC_GearInPos, MC_GearIn, MC_Cam: Handle situation if motion FB of master axis is called later in the cycle
  • [SM-3809] Implement SMC_GroupReadRemainingTrajectoryDuration for querying the remaining duration of a trajectory
  • [SM-4088] SMC_FB_WASNT_CALLED_DURING_MOTION: The last FB instance that had control of the axis should be logged
  • [SM-4266] SM3_Drive_ETC: improve logging of acyclic communication errors of EtherCAT drives
  • [SM-4279] Deprecate SMC_CAM_ObjectManager
  • [SM-4298] Improve documentation for error SMC_CP_QUEUE_UNDERRUN
  • [SM-4300] Kin_4AxesPalletizer: Document the singularity at (A,B,C) = (0,0,0)
  • [SM-4348] Integrate improved depictor models
  • [SM-4373] SMC_GroupReadPathDynamics: Make it possible to query the path dynamics in the future
  • [SM-4412] Implement SMC_GroupReadPositionInMovement for querying the current relative position in a movement
  • [SM-4478] SMC_ChangeDynamicLimits: The documentation should include, that the values are interpreted based on the gear output
  • [SM-4510] MC_GroupReadStatus: Add new outputs CurrentPlanningForecast and CurrentSyncBufferDuration
  • [SM-4513] Improve the error message of SMC_AXIS_GROUP_FOLLOW_SETVALUE
  • [SM-4522] SMC_GroupReadPathDynamics: Default CoordSystem should be MCS
  • [SM-4526] Document that administrative function blocks that use ReadPosition output the configuration with automatic periods
  • [SM-4532] Integrate SoftMotion Driver for BRC ctrlX DRIVE over CoE
  • [SM-4533] Integrate Softmotion Driver for WEG SCA06
Major Bug-Fixes
  • [SM-1997] Cam: Tappets on Cam object used on multiple axes do not work correctly
  • [SM-4265] CNC: If special characters are entered in a CNC editor, e.g. “///”, an unhandled error appears
  • [SM-4325] SMC_ToolRadiusCorr: Does not work correctly when using rotated decoder coordinate system in 2D mode
  • [SM-4455] Possible division by zero / NaN in trajectory generation (e.g. MC_MoveAbsolute)
  • [SM-4515] Halt/Stop: a halt with ClearMovement=FALSE might clear unposted movements when it is done
Minor Bug-Fixes
  • [SM-2983] CAN-CMZ-SD-ISD: 03_Homing_DriveStart fail on reenable drive
  • [SM-3976] MC_GearInPos: No error is reported if the controller mode is not position or velocity
  • [SM-4112] OrientationMode Axis with Kin_Scara2_Z: if the tool in x-direction is longer than arm2, error SMC_TRAFO_INVALID_PARAMETERS might occur
  • [SM-4236] CAN CMZ SD: Drive cannot be enabled after homing has been aborted by quick stop
  • [SM-4290] CNC object with Compile Mode SMC_OutQueue or SMC_CNC_REF will lead to new warning C0564 with SP20
  • [SM-4302] SMC_ChangeGearingRatio: Division by zero exception if the current dwRatioTechUnitsDenom = 0 or iRatioTechUnitsNum = 0
  • [SM-4304] SMC_GroupSaveContinueData: Aborting movements might be omitted when saving continue data
  • [SM-4309] SMC_ToolRadiusCorr: Documentation has an example where the correction plane is changed
  • [SM-4326] SoftMotion Libraries contain symbols without namespace or prefix
  • [SM-4352] Blending between dynamic coordinate systems with TMCornerDistance might not respect the configured corner distance
  • [SM-4362] fSetJerk does not get reset during a quickstop in velocity or position controller mode
  • [SM-4372] Errors during installation of the SoftMotion package >= 4.14.0.0 with CODESYS SP16
  • [SM-4385] An internal error (SMC_CP_INTERNAL_EVAL_CACHE_ERROR) may occur during a reset
  • [SM-4387] MC_GroupContinue: SMC_AXIS_GROUP_CONTINUE_WRONG_POSITION might be falsely reported
  • [SM-4388] Path deviation too high when tracking out
  • [SM-4472] Some Diagnostic POUs return Valid = True even when the axis group is disabled
  • [SM-4512] Keba KeDrive D3: Invalid Device Id of ETC Slave DA33x
General
    The error SMC_CI_MORE_THAN_32_ACCESSES will now be reported if more than 32 MC_CamIn instances use the same MC_CAM_REF instance at the same time.
    The SMC_CAM_ObjectManager (g_CAMManager) has been deprecated and will no longer be available in future versions of SoftMotion.
    Several internal functions, GVLs, and interfaces that did not have the prefix “SMC” were renamed. For example, the internal GVL “Constants” from SM3_Math.library has been renamed to SMC_Math_Constants.
  • [SM-4333] Revise the dimensioning of constant values for triggers and publish them as library parameters
    For customers that implement their own library resolved by placeholder SM3_CPKernelDefaults. The library has been extended by a new function GetDefaultPlanningForecastDuration. Additionally, a new library parameter ‘LibParams.MAX_NUM_TRIGGERS_PER_MOVEMENT’ of type UDINT has been added to the library. Please see the SoftMotion OEM documentation, chapter 5.2, for more details.
    In accordance to the naming convention of the data FBs in SM3_Depictor, ‘SMC_R_CAxisTool’ has been renamed to ‘SMC_R_CAxisTool_Data’.
    The default value for the CoordSystem input of SMC_GroupReadPathDynamics is now MCS instead of ACS. This was changed since ACS is not supported and led (and still leads) to an error.
  • [SM-3498] SM3_Drive_ETC_CMZ_BD: SMC3_ReinitDrive causes a new configuration of the Distributed Clock
    For several SoftMotion drivers, the undocumented inputs xHook_WaitInPreOp and xHook_WaitInSaveOp have been removed.
    These drivers are affected:
    • SM3_Drive_ETC_CMZ_BD
    • SM3_Drive_ETC_CMZ_SBD
    • SM3_Drive_ETC_Bonfiglioli_iBMD
    • SM3_Drive_ETC_KEB_iTMotorB
Known Limitations
project = “CODESYS SoftMotion” AND fixVersion = 4.15.0.0
project = “CODESYS SoftMotion” AND fixVersion = 4.15.0.0 AND (text ~ COMPATIBILITY_INFORMATION OR text ~ KNOWN_LIMITATIONS)
28.07.2023
Release Note
This is a maintenance release focusing on bug fixes and small improvements.
  • [SM-3057] Saving of continue data: save continue data of CP kernel in planning task
  • [SM-3940] Kin_Scara2_Z, Kin_Scara3_Z: Update documentation and allowed offset range
  • [SM-3943] Robotics: improve documentation of CommandAccepted output
  • [SM-4022] SMC_Interpolator: It should be possible to change the dJerkMax input while the interpolator is running
  • [SM-4034] MC_ReadParameter: adjust unclear description
  • [SM-4096] SMC_ToolRadiusCorr: Improve documentation for tool radius correction with G0
  • [SM-4119] Improve documentation of MC_PositionProfile, MC_VelocityProfile and MC_AccelerationProfile
Major Bug-Fixes
  • [SM-4089] Modulo axes: error in check continue position
Minor Bug-Fixes
  • [SM-2145] DeviceEditorSoftMotion: When adding more than one axis to an EtherCAT slave, the additional axes initially show a wrong mapping
  • [SM-3950] Cam-Editor, Tappets: Unhandled exception when adding a tappet track to a Cam object that already has 99 tracks
  • [SM-4055] SMC_GroupReadTargetPosition: A valid target position might be falsely reported
  • [SM-4085] SMC_ToolRadiusCorr: Very large tool radius (10^300) leads to problems
  • [SM-4136] SELXM32M contains invalid path characters in icon path.
General
This version is compatible with CODESYS V3.5 SP17 and newer. However we recommend the latest patch level of CODESYS V3.5 SP18.
    The dJerkMax input of SMC_Interpolator can now be changed while the interpolator is running. The value will become active - at the start of the interpolator - or once a standstill has been reached (between two G-code commands, due to a stop or caused by a override value of 0),
project = “CODESYS SoftMotion” AND fixVersion = 4.14.0.0
project = “CODESYS SoftMotion” AND fixVersion = 4.14.0.0 AND (text ~ COMPATIBILITY_INFORMATION OR text ~ KNOWN_LIMITATIONS)
13.03.2023
Release Note
Main content of this new realease is the support for pilot torque control and torque limitation for CODESYS Robotics. Kinematics can be extended by their dynamic model.
Apart from this improvements and bug fixes in different fields have been implemented.
New driver support for CMZ models SBD, IBD, IBD60 and NBD.
  • [SM-2947] Robotics: Torque Limitation
    • [SM-2968] Torque Limitation: Interface for dynamic models
    • [SM-2970] Torque Limitation: Integrate dynamic model into path invariant Halt/Stop
    • [SM-3040] Torque Limitation: Finalize the interface and implementation of SMC_GroupSetDynamics
    • [SM-3041] Torque Limitation: Implement override/scaling factors for torque limits
    • [SM-3897] Torque Limitation: Set torques should be checked
    • [SM-3911] Example for creating and using a dynamic model
    • [SM-3913] Implement SMC_GroupSetLoad
    • [SM-3937] AxisGroup should write fSetTorque if a dynamic model has been configured
    • [SM-3952] AXIS_REF_SM3: It should be possible to configure a torque software limit
    • [SM-3961] Torque Limitation: It should be possible to set the gravitational acceleration vector
    • [SM-3962] Torque Limitation: It should be possible to set a unit conversion factor from user units to meters
    • [SM-3965] Torque Limitation: Adjust dynamic models to consider loads
    • [SM-3984] Torque Limitation: Reset load when a new dynamic model is set
    • [SM-3985] Torque Limitation: Make it possible to define an execution mode for SMC_GroupSetLoad
    • [SM-3997] Torque Limitation: Changing the dynamic model should only be allowed while the axis group is disabled
  • [SM-2436] Detect wrong task configuration: create an axis group error if motion calls are not performed from bus task
  • [SM-2748] SMC_ToolRadiusCorr: Make FB more robust
  • [SM-3530] Detect wrong task configuration: create an axis error if motion calls are not performed from bus task
  • [SM-3623] Parker: Update the Compax3 devices
  • [SM-3763] SMC_ToolRadiusCorr: Restructure the internal state machine
  • [SM-3773] AxisGroup: eliminate m_fMaxBrakeDuration
  • [SM-3815] SM3_Drive_ETC_Parker (Compax 3): Write trigger input for capturing to 4 if not part of SDO config
  • [SM-3841] Detect wrong task configuration for CNC: create an error if CNC function blocks are called from wrong task
  • [SM-3872] MC_GroupHalt/Stop, Tracking: It should be possible to release dynamic coordinate systems after a tracking movement has been stopped
  • [SM-3889] Consolidate CALLED_FROM_WRONG_TASK errors
  • [SM-3923] SM3_Drive_ETC_Delta_R1_EC5621: Avoid sending unsupported SDO read requests on startup
  • [SM-3936] Make it possible to configure the gear ratio for fSetTorque
  • [SM-3996] Integrate new Softmotion driver for CMZ SBD
  • [SM-4044] Kollmorgen: Update the Esi files for AKD2G and AKD-C/N to V02.10.03.000
Major Bug-Fixes
  • [SM-3980] Using a quadratic velocity profile and setting the jerk to 0 may lead to a division by zero exception
  • [SM-4058] After calling SMC3_ReinitDrive, in rare cases acyclic communication may get stuck
Minor Bug-Fixes
  • [SM-2401] MC_Power: Error and ErrorID cannot be reset
  • [SM-2845] SM3_Drive_ETC_JAT_EcoVario, SM3_Drive_CAN_JAT: log error and set FB error if nAxisState is set to errorstop due to bit 11
  • [SM-3688] Driver for Keba KeDrive D3: change name from Keba_LTiMotion_ServoOne to KeDrive D3 where appropriate
  • [SM-3858] Wrong device identification Id in Staubli uniVAL device descriptions
  • [SM-3864] SM_Axis: layout/range of scroll bars does not show all the contents when the window size is reduced
  • [SM-3878] SMC_GroupJog2: In some cases no jogging is performed with ABC_as_ACS
  • [SM-3886] SM3_Robotics: The error SMC_CP_PLANNER_NO_PROGRESS might be reported when multiple axis groups are planning on the same core
  • [SM-3890] Part1 Motion POUs: The Error and ErrorID outputs are blinking during an active axis error and Execute = FALSE
  • [SM-3909] SMC_SmoothPath: eAddAxisMode SPAA_EXACT is missing in offline CNC settings
  • [SM-3922] AXIS_REF_POSCONTROL: By default, if in.bLimitPos/Neg are not written, no hardware limit error should result
  • [SM-3926] SMC_GroupJog2: Large values of MaxAngularDistance lead to a wrong movement of modulo axes
  • [SM-3931] MC_GroupContinue, Tracking: SMC_AXIS_GROUP_CONTINUE_WRONG_POSITION might be reported, even though the axis group is at the correct position
  • [SM-3949] PTP Tracking: possible axis jumps in the start or target position
  • [SM-3957] AutoMoveGantry, Tracking: SMC_PATH_QUEUE_INTERNAL_ERROR during interrupt
  • [SM-3989] MC_EXECUTION_MODE: wrong interpretation of mode queued
  • [SM-4027] SMC_GroupSaveContinueData: Saving continue data for an interrupted axis group is not handled correctly
Compatibility Information
General
This version is compatible with CODESYS V3.5 SP16 and newer. However we recommend the latest patch level of CODESYS V3.5 SP18.
    Setting the maximum brake duration with SMC_TuneCPKernel has been deprecated. The limitation to a maximum brake duration has been removed from the robotics trajectory planning. As a result, movements with a brake duration of more than 1 second can now be commanded without any tuning.
    Note that existing applications that were limited by the maximum brake duration may behave differently now and result in faster and smoother trajectories.
    As the Id of the Staubli uniVAL device descriptions has been changed, an update to the newest version is not automatically proposed for existing projects. Please update the uniVAL devices in the device tree to the new Id and version. (The device dialog will show both the old device in version 4.12.0.0 and the new device in version 4.13.0.0 with the same name, as the Ids are different.)
    With version 4.12.0.0 movements and their references to dynamic coordinate systems were kept in the axis group, even after an MC_GroupHalt/Stop was Done. This allowed continuing from the stop position, but also meant that dynamic coordinate systems that were referenced by those movements remained “InUse”. Starting with version 4.13.0.0, MC_GroupHalt/Stop has the input “ClearMovements” with a default value of TRUE. This means that by default all movements and coordinate system references are cleared once an MC_GroupHalt/Stop reports “Done” and all dynamic coordinate systems will no longer be “InUse”. Setting the “ClearMovements” input to FALSE restores the behavior introduced with version 4.12.0.0 and allows continuing from the stop position using SMC_GroupSaveContinueData and MC_GroupContinue.
    Up until version 4.13.0.0, MC_EXECUTION_MODE was only used for SMC_GroupSetAncillaryAxisLimits and SMC_GroupSetAncillaryPathLimits. For these two function blocks, the implementation of execution mode “Queued” differed from the behavior specified by PLCopen MC Part4. For version 4.13.0.0, the behavior of execution mode “Queued” was changed so that it is in compliance with the PLCopen definition. A new execution mode “NextCommanded” was introduced that implements the previous behavior of execution mode “Queued”.
    According to PLCopen MC Part 4, with execution mode “Queued” “the new functionality becomes valid when all previous motion commands set one of the following output parameters: Done, Aborted or Error”, i.e. have in some way finished. For SMC_GroupSetAncillaryAxisLimits and SMC_GroupSetAncillaryPathLimits, the execution mode “Queued” was implemented such that the ancillary limits became effective once the next commanded movement started. As long as only static coordinate systems are used, this does not make a difference, since the axis group will be in standstill after all previous movements have finished and before the next movement starts. However, it can make a difference when dynamic coordinate systems are used. In this case, the axis group might not be in standstill, but following a moving coordinate system and different ancillary axis limits can affect the movement of the axis group. In particular, different ancillary axis limits can determine whether the axis group is able to follow the dynamic coordinate system.
Information from JIRA
List of features and changes:
project = “CODESYS SoftMotion” AND fixVersion = 4.13.0.0
project = “CODESYS SoftMotion” AND fixVersion = 4.13.0.0 AND (text ~ COMPATIBILITY_INFORMATION OR text ~ KNOWN_LIMITATIONS)
19.12.2022
Release Note
CODESYS SoftMotion 4.12.0.0 brings support for modulo axes to robotics and improved support for continuing after a MC_GroupStop/MC_GroupHalt, as well as new example projects for CNC (use of additional axes and use of tool length correction).
In the field of PLCopen master/slave blocks, MC_CamIn was revised, especially switching between cam tables.
Support for Staubli model CS9 has been added to the UniVal driver.
Major bugs have been fixed in SMC_SmoothMerge, MC_GroupReset and for PTP movements with a configuration change.
  • [SM-2311] Robotics: Support for modulo-axes
    • [SM-323] Robotics: Handling of modulo-axes
    • [SM-3767] Robotics: Handling of modulo-axes: change meaning of AxisSettings and GetAxisProperties
  • [SM-3665] Resume after MC_GroupHalt/MC_GroupStop: continue at stop position
    • [SM-3696] Resume after MC_GroupHalt/MC_GroupStop: Change halt/stop from movement to state in axis group
    • [SM-3697] Resume after MC_GroupHalt/MC_GroupStop
    • [SM-3701] Resume after MC_GroupHalt/MC_GroupStop: Update AXIS_GROUP_REF_SM3.GetMovementQueueReserve
    • [SM-3714] Resume after MC_GroupHalt/MC_GroupStop: Check and fix library documentation and specification
  • [SM-641] MC_GroupReadActualVelocity/Acceleration, SMC_GroupReadSetVelocity/Acceleration: support for output PathVelocity/PathAcceleration/PathJerk
  • [SM-1924] SMC_ReadNCFile2: include bExecute and bAbort
  • [SM-2496] SMC_GroupJog2: The default value for Vel/Acc/JerkFactor should be 0
  • [SM-2561] Robotics: Make it possible to change the limit of velocity, acceleration, and jerk for each axis
  • [SM-2813] Create an SDK for the SoftMotion AddOn
  • [SM-2979] SM3_Drive_ETC_Parker (Compax 3): update touch probe function by reading source from object 0x2303.0x20
  • [SM-3323] Make it possible to declare and use a local logical axis inside a function block
  • [SM-3324] CNC: allow indirect subprogram calls using string variables instead of the subprogram name
  • [SM-3343] Robotics: function block SMC_GroupAddOffset to add an offset to a position
  • [SM-3509] ElemFunCS_Delta: The function should return an identity frame in case of equal coordinate systems
  • [SM-3627] Robotics: read information about axes (position or orientation axis)
  • [SM-3680] SM3_Drive_ETC_Staubli_uniVAL: support CS9
  • [SM-3681] SMC_ReadNCFile2: make it easier to read from arbitrary streams and to modify the g-code
  • [SM-3699] [Docu] SMC_NCDecoder and SMC_NCInterpreter: document which values of piStartPosition are actually used
  • [SM-3713] SMC_ToolRadiusCorr: make it possible to define an offset for the tool radius
  • [SM-3718] SMC_GroupConvertPosition: The kinematic configuration should be returned when converting from ACS to a cartesian coordinate system
  • [SM-3722] Deprecate SMC3_CaptureDescription.bLatchInController
  • [SM-3723] Generic CiA 402 axis: allow more than 8 drivers per slave if supported
  • [SM-3736] MC_TouchProbe: change default of MC_TRIGGER_REF.iTriggerNumber from -1 to 0 and add check for invalid trigger numbers
  • [SM-3746] MC_MoveSuperimposed: make it possible to halt a superimposed movement
  • [SM-3775] SMC_MovementCommand: Avoid huge data structures on the stack
Major Bug-Fixes
  • [SM-3527] SMC_SmoothMerge: Merging results in an undesired loop movement
  • [SM-3621] SMC_SmoothMerge: Merging of an orientation movement results in an undesired movement of the orientation axis
  • [SM-3745] Jump in axis positions when moving between configurations with PTP movement
  • [SM-3762] Possible AccessViolation after a MC_GroupReset
  • [SM-3823] Finite logical axis below modulo master now behaves like a modulo axis
Minor Bug-Fixes
  • [SM-246] CiA-402 base driver: the generic limit switch checks does not respect Axis.bHWLimitEnable
  • [SM-2270] SMC_GroupJog2: The axisgroup jogs even when an irrelevant axis is fired
  • [SM-2497] SMC_GroupJog2: AxisGroup can start moving in unexpected directions
  • [SM-2739] SMC_ToolRadiusCorr computes wrong path
  • [SM-2774] Possible jump in axis positions aftert MC_GroupContinue
  • [SM-2838] MC_CamIn: periodic tabular cams (byType XYVA) with many points: long runtime if cam period is reached
  • [SM-2929] CNC program can be added to POU window although SoftMotion is disabled
  • [SM-2946] SMC_GroupJog2: reset Error output on falling edge of Enable
  • [SM-2978] PlugIn: There may be multiple implicit General Axis Pool connectors in a project
  • [SM-3104] SMC_GroupJog2: generates error when running onto border of working area
  • [SM-3178] SoftMotion on standard PLC: Logical axis below general axis pool disappears when updating the device
  • [SM-3207] CNC: Wrong errorpos and error Id if a subprogram cannot be found
  • [SM-3239] Settings: Unhandled Exception on creating new project
  • [SM-3313] MC_MoveLinearAbsolute, Override: VelFactor zero “0” can leave the FB in a non-quit state
  • [SM-3330] Jogging in a dynamic PCS which is in standstill might not be possible
  • [SM-3354] Resume after error: Movements do not finish when MC_GroupContinue is used for an aborted interrupt
  • [SM-3451] MC_TouchProbe: May Report Done multiple times for the same trigger event if the touch probe objects are mapped as PDOs
  • [SM-3521] Fix the documentation for wAuxData of SMC_POSINFO
  • [SM-3526] MC_CamIn: Switching cams no longer works as documented
  • [SM-3607] Possible unjustified error SMC_CP_TRAJECTORY_NOT_SMOOTH
  • [SM-3611] MC_TouchProbe: With bFastLatching = FALSE, edge detection of the trigger input should be supported
  • [SM-3624] MC_GroupSetOverride: Setting the override to 0 and then setting it to >0 while the axis group is stopping does not work
  • [SM-3636] SMC_Interpolator: The segmenter is not reset with a rising Execute edge
  • [SM-3652] Single axis movements: possible jumps in trajectory with ramp type sin^2 and blending or aborting
  • [SM-3659] Tracking: Jump in rotary axis (period missmatch) after aborting movement
  • [SM-3668] SMRCP, Planer: AXIS_MAX_VEL constraint does not consider derivatives wrt t
  • [SM-3671] MC_GroupStop: Axis group switches to state “stop_done” without having posted the stop movement yet
  • [SM-3691] MC_SetDynCoordTransform: GetPose does not return exact save-pos for fTime=0 and uses acceleration and jerk for extrapolation
  • [SM-3698] OriPrimLinear: singularity if orientation difference is close to a multiple of 2*pi
  • [SM-3705] Assertion in TrajectoryPlanner.StateMachine because CheckInvariant fails
  • [SM-3706] MC_Home might get stuck in reading the position offset
  • [SM-3710] SMC_AXIS_GROUP_PATH_DEVIATION_TOO_HIGH after continue of position in dynamic PCS
  • [SM-3737] Interrupt/Continue: The first movement after a continue without movement to the continue position is reporting done to early
  • [SM-3739] Update PLC Device from device that has SoftMotion disabled to SoftMotion device (type 0x1006): compile errors
  • [SM-3742] Tracking: When commanding two consecutive MC_GroupInterrupt during tracking, the second one will not finish
  • [SM-3751] SMC_Interpolator may return error SMC_INT_QPROF_DIVERGES
  • [SM-3772] MC_MoveCircularRelative: Coordinate system ACS is not treated correctly
  • [SM-3774] AutoMoveGantry, Multicore: Access violation in ElemFunTrace_StartCycle
  • [SM-3810] SM_Drive_PosControl: default for velocity pilot control is 0 (no velocity pilot control) but should be 1
General
    The default values of the inputs VelFactor, AccFactor, and JerkFactor of SMC_GroupJog2 have been changed from 1 to 0. Applications that are using SMC_GroupJog2 and did not change the default of these inputs need to be adapted. The reason for the change is that certain jogging movements may be very fast when all factors are 1. For example when jogging in the ACS, the full global axis limtis may be used for the jogging movements.
    The function block SMC_SetDynamicLimitFactors has been deprecated. Please use SMC_GroupSetAxisLimitFactors or SMC_GroupSetAncillaryAxisLimits instead.
    SMC_ToolRadiusCorr: The order of elements in the out-queue (poqDataOut: SMC_OUTQUEUE) changes compared to previous versions, if (and only if):
    • a correction arc has been inserted between two cartesian elements A and B at an outer corner, and
    • non-cartesian elements (e.g. M-functions) are situated between the two elements.
    In previous versions, the non-cartesian elements were inserted into the queue after the correction arc. However, the position of the non-cartesian elements was set to the start position of the arc. This was a bug and could lead to jumps if no subsequent path processing FB corrected the error (set the position of the non-cartesian elements to the end postion of the arc).
    As of version 4.12.0.0, the arc will always be inserted _after_ the non-cartesian elements right before B. The position of the non-cartesian elements is equal to the start postion of the arc.
    Example: Consider the following G-code:
    N000 G42 D1
    N010 G01 X1 F100 (Ramp-in to A)
    N020 G01 X2 Y0 Z0 (A)
    N030 M4
    N040 M5
    N050 M6
    N060 G01 X2 Y1 Z0 (B)
    With version 4.12.0.0, the output of SMC_ToolRadiusCorr will correspond to the following G-code:
    N000 G01 X1 Y-1 D1 F100 (Ramp-in to A)
    N010 G01 X2 Y-1 Z0 (A)
    N020 M4
    N030 M5
    N040 M7
    N050 G03 X3 Y0 R1 (Correction-Arc)
    N060 G01 X3 Y1 Z0 (B)
    SMC_GroupJog2 now reports an error when trying to jog in a dynamic coordinate system.
    The treatment of rotary axis limits has been changed. For existing applications this can lead to a change in the path of the robot in certain cases, especially if the software limits for rotary axes have not been set in the SoftMotion drive editor (tab “General”).
    Important: when upgrading to 4.12.0.0, make sure all SoftMotion drives have suitable software limits set before moving the robot. Existing motion programs must be tested again, preferably with reduced velocity.
    For authors of kinematic function blocks, the handling of axis limits has been simplified. The interface ISMKinematicAxisSettings no longer needs to be implemented, except for the rare cases where the axis limits are needed for the kinematic transformation. In the method GetAxisProperties, which is still required if the kinematics contains rotary joints, no limits should be returned, except for the rare case that the rotary joint should be limited to a specific range. (Note that such a limit will make it impossible to connect a modulo axis to the joint.)
project = “CODESYS SoftMotion” AND fixVersion = 4.12.0.0
project = “CODESYS SoftMotion” AND fixVersion = 4.12.0.0 AND (text ~ COMPATIBILITY_INFORMATION OR text ~ KNOWN_LIMITATIONS)
08.07.2022
Release Note
SoftMotion 4.11.0.0 brings improved tracking of conveyor belts and rotary tables for Robotics, several new and improved functions for single axes, new drivers for servo drives as well es many bug fixes.
Especially for Robotics, this is a major update. Please take care when updating existing applications. See the section “Compatibility Information” below for details.
  • [SM-2276] Improved CP-Tracking for Pick&Place applications
    • [SM-961] CP-Tracking: Support orientation interpolation mode “Axis” also for CP-Tracking
    • [SM-2159] CP-Tracking: support pure orientation movements
    • [SM-2160] CP-Tracking: support orientation mode Axis
    • [SM-2161] CP-Tracking: support elements that are not parametrized by arc length
    • [SM-2162] CP-Tracking: support improved cartesian composite blending
    • [SM-2235] CP-Tracking: improve blending if tangent and curvature matches
    • [SM-2259] CP-Tracking: MC_GroupStop/MC_GroupHalt, CP-Tracking: immediate braking with given dynamic limits
    • [SM-2697] CP-Tracking: Implement PTP_PI Tracking
    • [SM-2707] CP-Tracking: implement OriPrimAxis for tracking
    • [SM-2709] CP-Tracking: Composite blending for orientation mode axis
    • [SM-2765] CP-Tracking: implement aborting
    • [SM-2955] Remove PTP kernel (support for PTP fast movements)
    • [SM-2988] SMC_GroupJog: implement based on new CP-Tracking kernel and deprecate
    • [SM-3021] CP-Tracking: Unify blending to composite blending
    • [SM-3100] CP-Tracking: Check the conditions for not inserting a blending element
    • [SM-3173] CP-Tracking: Handle Interrupt/Continue while moving between dynamic coordinate systems
    • [SM-3279] CP-Tracking: Implement the De Boor algorithm to improve interpolation of dynamic coordinate system states
    • [SM-3306] SMC_AxisGroup_Tracker: a movement should only report done if the tracker is also done
    • [SM-3460] CP-Tracking: Implement replacement for “aRefElem” in axis space elements
    • [SM-3471] CP-Tracking, OriPrimLinear: Handle orientation changes > 180°
  • [SM-80] Logical Axis: Improve filter
  • [SM-101] Integrate driver for Nidec ControlTechniques Unidrive M
  • [SM-2516] Switch SoftMotion Package to Core Separation and SP16 SDK
  • [SM-2558] Integrate Keba drive ServoOne CM
  • [SM-2577] Improve the behavior of MC_GroupHalt/Stop with low dynamics
  • [SM-2644] Robotics: path velocity, acceleration, and jerk should be accessible, SMC_GroupReadPathDynamics
  • [SM-2916] Build: SoftMotion package must be signed
  • [SM-2934] Robotics: create function blocks SMC_GroupReadSetJerk
  • [SM-2940] Robotics, CP: Synchronize movement queues between bustask and planner together with the various requests in an Atomic_SRSW
  • [SM-2956] Robotics: Deprecate SMC_SetMovementQueueBuffer
  • [SM-2982] SoftMotion: Subcategory for delta drives different from other delta Ethercat Slaves
  • [SM-2993] Blending: Improve blending between straight lines with a 90 degree angle
  • [SM-2994] SM3_Transformation: Support custom position limits for all axes of Kin_Pos_RRR and Kin_Wrist3
  • [SM-3061] MC_GroupReset should always reset axis errors
  • [SM-3086] Command “Enable SoftMotion”: don’t use first free connector-id (GetFreeConnectorId)
  • [SM-3105] Bosch Rexroth IndraDrive CS: add link to application note to drive documentation
  • [SM-3107] Integrate Kollmorgen AKD2G Drive
  • [SM-3108] Integrate kollmorgen AKD-N/C Drive
  • [SM-3109] Integrate kollmorgen MKD-N/C Drive
  • [SM-3110] Integrate Panasonic A6 Multi Drive
  • [SM-3112] Integrate the new Devdescs for Panasonic MINAS A6B
  • [SM-3157] SMC_SolveTwoRotJoint should return exactly the same angles for elbow low/high up to a constant offset
  • [SM-3220] Resume after error: An active interrupt(At) should be saved in the continue data for resume after error
  • [SM-3310] Add possibility to query movement id of interrupt position from continue data
  • [SM-3349] SMC_TrackSetValues: new part 1 function block to track a signal given limits on velocity, acceleration, and jerk
  • [SM-3446] Integrate Nidec ControlTechniques UniDrive M
Bug-Fixes
  • [SM-1156] MC_GroupInterrupt, MC_GroupContinue, SMC_GroupSaveContinueData, Resume after Error: possible jump in axis position for PTP tracking movements
  • [SM-1960] CP: OrientationMode Axis: bad blending elements in case of differing ori/cart-ratio
  • [SM-2221] CP-Tracking: SMC_GroupWait does not work with wait times that are smaller than or a multiple of the cycle time
  • [SM-2458] CP-Tracking: MC_GroupContinue only works if called _after_ the PCS has been updated
  • [SM-2470] CP-Tracking: error in circular movement not propagated to axis group and movement function block
  • [SM-2517] CP, PTP_PI: MC_GroupInterrupt can influence the start position of an aborting movement
  • [SM-2522] AutoMoveGantry: Rotary axis range violation
  • [SM-2592] AutoMoveGantry: Axis limit violation after continue
  • [SM-2636] Scaling/Mapping page: setting of motor type (linear / rotary) is not persisted
  • [SM-2647] CutEndDistMode may fail, leading to buffered movement and assertions in the test
  • [SM-2677] PTP, TMCornerDistance: Finding Point A fails
  • [SM-2756] AutoMoveGantry: GetARefForPos fails because of missing cache element
  • [SM-2864] AxisGroup: Endless Moving-State if multiple constant movements are commanded
  • [SM-2930] “SoftMotion General Axis Pool” has red error icon if device diagnosis is turned off
  • [SM-2939] SMC_TRAFO_Tripod_Arm creates cyclic license missing messages
  • [SM-2954] Possible Assertion reading the continue data: GetCacheElemByS fails if Halt is executed shortly before end of segment
  • [SM-2963] Robotics, CPTR: SMC_AXIS_GROUP_CONTINUE_WRONG_POSITION during continue
  • [SM-2976] EtherCAT Mapping information: IECATPdoItemEntry without channel should be ignored
  • [SM-2977] Error SMC_TRAFO_INVALID_CONSTELLATION in RobotFactory project
  • [SM-2991] MC_GroupInterrupt: Interrupt may halt at wrong interrupt position and save invalid continue data
  • [SM-3008] SMC_CP_Planning: Problems with aborting movement after previous movement is done and the aborting movement is commanded in a different CS
  • [SM-3009] Inst_MC_MoveLinearAbsolute: Problem with aborting movements and a transition between coordinate systems
  • [SM-3015] PTP Movements: error SMC_CP_INVALID_PATH_ELEM for very short movements
  • [SM-3016] PTP movements commanded in ACS: exact end position is not reached
  • [SM-3017] Robotics: unexpected error SMC_AXIS_GROUP_IDLE_WAIT_AXES_MOVING when commanding a movement and the axes are not powered on
  • [SM-3025] Robotics: Assertion in StateMaching_SetAxisStartPos if first commanded movement is PTP_PI with length 0
  • [SM-3026] PTP_PI: Assertion if the target position in ACS is outside the software limits
  • [SM-3053] MC_GroupInterrupt is not working during an active SMC_GroupWait
  • [SM-3062] AutoMoveGantry: SMC_CP_TRAJECTORY_NOT_SMOOTH
  • [SM-3068] Axis limit violation when starting a movement after having stopped and saved continue data
  • [SM-3074] CNC: SMC_ComputeTangentAngle might return NaN if tangents are codirectional
  • [SM-3091] SMC_GroupReadPlanningStatistics: Valid output is never set
  • [SM-3096] Description of input ABC_as_ACS of SMC_GroupJog2 is not clear
  • [SM-3117] The PathOut queue of the TrajectoryPlanner cannot handle a full PathIn queue, when the lookahead is at the end of the PathQueue
  • [SM-3121] Pause position in continue data
  • [SM-3126] CP_HaltStop: Assertion in InterpolateProfile
  • [SM-3144] LREAL_TO_DWORD with negative values may lead to errors
  • [SM-3168] Saving of continue data is very slow
  • [SM-3191] Robotics: Reproducibility: trajectory may differ if Trj_EvalCache is cut
  • [SM-3204] SMC_TRAFO_Tripod_Arm: z-coordinate is ignored
  • [SM-3206] Robotics: Blending elements: check if curvature is too high may use wrong interpolation parameter limits
  • [SM-3229] Possible error SMC_CP_ROTARY_AXIS_RANGE_VIOLATION with orientation mode axis
  • [SM-3230] SMC_GroupJog2: VelFactor, AccFactor and JerkFactor are not taken into account when jogging in ACS and outside of the working area
  • [SM-3231] An aborting movement from standstill may lead to an error
  • [SM-3233] Possible error SMC_CP_ROTARY_AXIS_PERIOD_MISMATCH with MC_MoveDirectRelative and very high dynamics
  • [SM-3235] SMC_FreeEncoder: fActVelocity, fSetVelocity, fActAcceleration, and fSetAcceleration are always 0 in simulation
  • [SM-3268] Cache, AxisBlending: Periods may be missed because of too few slots in the cache
  • [SM-3271] ResumeAfterError: Blocking movement if AddNewMovement fails
  • [SM-3273] Internal error SMC_CP_TRAJECTORY_NOT_SMOOTH
  • [SM-3309] PATH_DEVIATION_TOO_HIGH in Part4MotionTest “117_PTP_Override”
  • [SM-3317] CNC: SMC_CheckForLimits does not return correct iSourceLine_No
  • [SM-3325] ResumeAfterError: An active SMC_GroupInterruptAt should not result in a complete reset after a continue
  • [SM-3331] IControlCreation.CreateKinematicsSelector: if IsToolKinematics is TRUE, then only orientation kinematics should be shown
  • [SM-3352] SMC_Quat1_RotDist between the same quaternion does not always return exactly 0
  • [SM-3371] MC_ReadActualTorque: negative torque values not converted correctly for standard SoE driver
  • [SM-3379] MC_GearInPos: Sync in wrong master period and no immediate start of synchronisation with modulo master and MasterStartDistance=0
  • [SM-3466] CP-Tracking, SMC_GroupReadSetPosition returns incorrect values during tracking
  • [SM-3578] Movements that are called multiple times in a cycle might result in duplicate movement queue entries
  • [SM-3603] Possible assertion in Trj_Cycler
General
This version is compatible with CODESYS V3.5 SP16 and newer. However we recommend the latest patch level of CODESYS V3.5 SP17.
    The position and velocity filter of the logical axis has been reworked and improved. For the same settings, it should produce better results. In particular, the fActVelocity now better matches the fActPosition and noise on fActPosition is reduced effectively. For existing applications that use the logical axis to filter e.g. encoder values, please check your filtered signals using the trace to make sure you get the desired behavior with the improved filters.
    The SoftMotion package version 4.11.0.0 requires at least CODESYS version 3.5.16.0.
    The input MovementType of MC_MoveDirectAbsolute and MC_MoveDirectRelative has been deprecated. It will be removed in a future version. The movement type SMC_PTP_MOVEMENT_TYPE.Fast is no longer supported. Only the movement type SMC_PTP_MOVEMENT_TYPE.PTP_PI is supported.
    Important: applications using the movement type Fast need to be tested after switching to SoftMotion 4.11.0.0.
    Using SMC_SetMovementQueueBuffer will now lead to a compile warning stating that the function block is obsolete and will no longer be available in future versions of SoftMotion.
    The function block SMC_GroupJog has been deprecated and is superseded by SMC_GroupJog2. It is strongly recommended to use SMC_GroupJog2 for new projects and to change existing applications from SMC_GroupJog to SMC_GroupJog2.
    SMC_GroupJog no longer supports the input ABC_as_ACS. If this feature is required, please switch to SMC_GroupJog2.
    Robotics: The blending between movements has been changed. The same shape of blending is now applied, no matter what kind of movement (tracking or static, orientation mode axis or great circle). This means that the path of the TCP may (slightly) change during blending compared to previous versions of SoftMotion. Please test your application carefully when updating to this version.
    No blending element is inserted between two movements with matching tangent and curvature. Example: two semi circles commanded using MC_MoveCircularAbsolute to achieve a full circle. Another example: two straight lines having the same slope.
    With this change, blending is only omitted if all of the following conditions are met:
    • both movements are CP movements (MC_MoveLinear*, MC_MoveCircular*), and
    • both movements have been commanded in the same coordinate system, and
    • the start position of the first movement is also given in the same coordinate system, and
    • the movements don’t use orientation mode “Axis”.
    If an error occurs while MC_GroupInterrupt or SMC_GroupInterruptAt are active and SMC_GroupEnableResumeAfterError is enabled, the interrupt is now saved in the continue data of SMC_GroupEnableResumeAfterError. When continuing using this continue data, the interrupt will be executed.
  • [SM-3542] CP-Tracking, Interrupt/Continue: Rotary axes can jump to a different period after a continue
    Using MC_GroupContinue to continue from a position in a dynamic PCS now requires updating the continue data using SMC_GroupUpdateContinueData.
  • [SM-3065] CP-Tracking: support for relative movements with (static) cartesian start position and ACS distance
    There are restrictions on relative movements in combination with tracking. Relative movements are not supported in the following cases:
    1. The start position (end position of preceding movement) and distance of the relative movement are given in two different coordinate systems (CS) with at least one being dynamic, or
    2. the relative movement is an aborting movement and aborts an active
      • track-in (from a static CS to a dynamic CS),
      • track-out (from a dynamic CS to a static CS), or
      • re-track (from a dynamic CS to another dynamic CS) movement.
    The errors SMC_RELATIVE_MOVEMENT_TRACKING_CS or SMC_RELATIVE_MOVEMENT_ABORTING_TRACKING will be reported.
  • [SM-3252] TMCornerDistance for tracking PTP movements
    In case of tracking with PTP movements, the corner distance is evaluated when the axis group plans the trajectory on the blended path. This happens shortly before the axis group travels the path.
    Consequently, when the axis group travels the blending, the distance may be slightly different, depending on the movement of the tracked coordinate system.
  • [SM-3269] CP-Tracking: Circular movements not supported between different dynamic coordinate systems
    Commanding of circular movements (MC_MoveCircularRelative, MC_MoveCircularAbsolute) in combination with tracking (e.g. MC_TrackConveyorBelt) has the following restrictions:
    1. If the BufferMode is Buffered or a blending mode, then the circular movement must be commanded in the same coordinate system as the previous movement
    2. If the BufferMode is Aborting, then the circular movement must be commanded in the same coordinate system as the active movement
    3. If the BufferMode is Aborting, and the active movement is a (tracking) PTP movement, then no circular movement is supported.
Known Limitations
  • [SM-2314] MC_GroupStop/MC_GroupHalt, CP: immediate braking with given dynamic limits MC_GroupHalt of CP movements cannot be aborted. A subsequent movement is always treated as buffered.
project = “CODESYS SoftMotion” AND fixVersion = 4.11.0.0
project = “CODESYS SoftMotion” AND fixVersion = 4.11.0.0 AND (text ~ COMPATIBILITY_INFORMATION OR text ~ KNOWN_LIMITATIONS)
23.02.2022
Release Note
CODESYS SoftMotion 4.10.0.0 improves the robotics jogging function blocks and contains bug fixes.
  • [SM-2805] Robotics: Improve jogging
    • [SM-2779] SMC_GroupJog/ SMC_GroupJog2: Make it possible to jog around the X/Y/Z axis in TCS
    • [SM-2854] Improve jogging of orientation
    • [SM-2873] SMC_GroupJog2: remove/deprecate input OrientationMode
    • [SM-2883] SMC_GroupJog/SMC_GroupJog2: Improve FB documentation
    • [SM-2890] Jogging FB visus: update visu templates
    • [SM-2892] SMC_GroupJog2: Improve accuracy of reported error messages
  • [SM-2876] Robotics: SMC_GroupInterruptAt
    • [SM-2893] Robotics: SMC_GroupInterruptAt: New FB and visu template
    • [SM-2894] Robotics: SMC_GroupInterruptAt: Extend the CP planner to notify the fineinterpolator about the interrupt position in the sample queue
    • [SM-2895] Robotics: SMC_GroupInterruptAt: Implementation in CP planner
  • [SM-2899] CP, Planner: Improve debug and diagnosis functions
  • [SM-2909] DeviceEditorSoftMotion: add interface that allows third party EtherCAT configurators to provide the PDO mapping for slaves
Major Bug-Fixes
  • [SM-2472] SM3_Drive_CAN_Infranor and SM3_Drive_ETC_Infranor: SetPosition increases on Hardware Limit
  • [SM-2737] SMC_GroupJog2: Orientation mode Axis and ABC_as_ACS do not work in cartesian coordinate systems other than MCS
  • [SM-2907] “Enable SoftMotion” hides other connectors in PLC device
Minor Bug-Fixes
  • [SM-253] SM3_Drive_CAN_Schneider_Lexium32: FB ReInitDrive does not work when MC_ReadAxisError is busy
  • [SM-2369] SM3_ETC_ITF: Startup SDOs not correctly added to list
  • [SM-2771] SMC_GroupJog2: Jogging in TCS is erroneous
  • [SM-2772] SM3_Robotics_Visu: ComboBox entries not selectable + improvements for jogging
  • [SM-2777] SMC_GroupJog: Jogging in TCS with ABC_as_ACS does not work
  • [SM-2799] SMC_GroupJog2: Cartesian coordinate system and ABC_as_ACS = FALSE: orientation axes may rotate in unexpected direction
  • [SM-2802] SMC_GroupJog2: “AutomaticRotaryPeriods” are not considered
  • [SM-2834] CP-Tracking: axis limit violation with composite blending for orientation elements
  • [SM-2852] Part 1 function blocks: Done, Error and CommandAborted output is not immediately reset on Execute = FALSE
  • [SM-2860] SMC_GroupJog2: maxAngularDistance 360 deg behaves like 0 deg, 359 deg and 361 deg behave unexpectedly
  • [SM-2870] CP: planner may not accept any movements in case of m_ErrorIDNewMovement <> SMC_NO_ERROR
  • [SM-2875] CNC: SMC_NCTokenizer: tokenizer does not react correctly to stream.EOS
  • [SM-2882] SMC_GroupJog2: jogging X/Y/Z in TCS results in error SMC_CP_CONFIGS_DIFFER frequently
  • [SM-2897] Robotics: wrong check of axis limits for orientation mode axis and jogging with ABC_as_ACS = TRUE
  • [SM-2905] Possible null-reference exception in FindParentETC_Slave FindParentETC_Slave
  • [SM-2906] SMC_DSP402_ConvertReceivedParameter: status word of previous cycle is used
  • [SM-2926] Possible assertion when resuming with MC_GroupContinue after MC_GroupStop
  • [SM-2927] MC_GroupContinue during active MC_GroupStop results in AXIS_LIMIT_VIOLATION
General
This version is compatible with CODESYS V3.5 SP11 and newer. However we recommend the newest patch level of CODESYS V3.5 SP16.
    We fixed an accident introduced in version 4.7.0.0 with SM-2086 for our single axis and master/slave motion function blocks such as MC_MoveAbsolute. On a falling edge of the Execute input, the outputs Done, Error, and CommandAborted would stay TRUE for one more cycle. With this fix, we restored the correct behavior. Now the Done, Error, and CommandAborted outputs are reset immediately with the falling edge of Execute. This is the behavior of versions prior to 4.7.0.0.
    Jogging of the orientation with the function blocks SMC_GroupJog and SMC_GroupJog2 has been improved. The behavior has changed only for the case that the input ABC_as_ACS is FALSE.
    Previously, the ZYZ euler angles were jogged, leading to unpredictable and unintuitive reorientation movements. The improved behavior is as follows: A will rotate the TCP around the X-axis of the configured coordinate system (MCS, WCS, PCS, or TCS). B and C will rotate the TCP around the Y- and Z-axis of that same coordinate system.
    The input SMC_GroupJog2.OrientationMode has been deprecated and will be removed in a future version. Please adapt your code accordingly. If ABC_as_ACS is TRUE, then internally the orientation mode “Axis” is used. Otherwise, orientation mode “GreatCircle” is used.
  • [SM-2885] SMC_GroupJog2: Negative MaxLinear/AngularDistance reverses the jogging direction
    The function block SMC_GroupJog2 now creates the error SMC_GROUPJOG2_MAX_DISTANCE_NON_POSITIVE if either (or both) of the inputs MaxLinearDistance and MaxAngularDistance is non-positive.
Known Limitations
  • [SM-1901] ETC Drives using modular slaves not working with CODESYS SP13 and SP14 if SlotIndexIncrement is not 0. The mapping of drive objects in the Scaling/Mapping page of SoftMotion drives is computed incorrectly for some EtherCAT slaves and CODESYS versions. This happens if (and only if) all of the following conditions are met:
    • The slave is a multi axis slave, and
    • the slave uses modules, and
    • the attribute SlotIndexIncrement (in the ESI file) of the axis modules is not 0, and
    • the CODESYS version is below 3.5.15.0.
project = “CODESYS SoftMotion” AND fixVersion = 4.10.0.0
project = “CODESYS SoftMotion” AND fixVersion = 4.10.0.0 AND (text ~ COMPATIBILITY_INFORMATION OR text ~ KNOWN_LIMITATIONS)
24.02.2021
Release Note
CODESYS SoftMotion 4.9.0.0 brings important bug fixes and improvements.
Improvements
  • [SM-2712] Make SoftMotion work on PLCs with all target types, not only the SoftMotion target type 16#1006
  • [SM-2619] Kin_Wrist2: allow an offset in x, y and z between first axis of rotation (A) and second axis of rotation (B)
  • [SM-2610] Kin_Wrist2: allow tool offsets in X/Y with SMC_GroupSetTool if flange of position kinematics is constant
  • [SM-2617] Kin_ArticulatedRobot_6DOF: extend kinematics to support axis offsets
  • [SM-2711] Make it possible to filter log messages of SoftMotion by logger class
Major bug-fixes
  • [SM-2781] SM3_Drive_ETC: SDO read and write FBs don’t receive falling edge on xExecute after xDone/xError. This can lead to axes not working if many EtherCAT drives are used and many SDO requests are issued. (E.g. an application with 50 drives where the mode of operation and mode of operation display objects are not mapped by PDO.)
  • [SM-2710] SMC_ToolRadiusCorr computes wrong path if lines are orthogonal
  • [SM-2704] CPTR: Assertion Failure in GetPose of Kernel_CPTR
  • [SM-2671] MC_TrackConveyorBelt does not support logical axes
  • [SM-2670] Wrong Velocity calculation in driver for Delta ASDA A3 and B3
20 minor bugs have been fixed.
Supported drives
  • [SM-2826] Support for Bosch Rexroth Indradrive (EtherCAT, CoE)
  • [SM-2675, SM-2679] Delta IO – R1-EC5621: touch probe support, set the correct input pulse mode on the drive startup
  • [SM-143] Schneider Lexium32 CAN+EtherCAT: update to new device description and firmware (V01.28.03)
  • [SM-2782] Infranor PAC, CMZ LBD: Log messages about capture channels should be DEBUG, not INFO
  • [SM-2778] Schneider Lexium 28: Bugfix: no reset possible after homing is interrupted by a limit switch
  • [SM-2722] Parker Compax3: Log messages about startup SDOs and firmware info should be DEBUG, not INFO
  • [SM-2651] Parker PSD: Update to new device description
  • [SM-2167] Panasonic A6B: Update to new ESI file and integrate the drive
General
  • [SM-2712] Make SoftMotion work on PLCs with all target types, not only the SoftMotion target type 16#1006. SoftMotion can now be used on standard PLCs. This means that SoftMotion objects such as Cam tables, CNC programs, and axis groups can be added to standard PLCs. For a standard PLC, SoftMotion is initially not enabled. It can be enabled using a new command “Enable SoftMotion” or by adding a SoftMotion object or drive. Once it is enabled, the SoftMotion libraries will be added to the library manager automatically, just like for a SoftMotion PLC. A “General Axis Pool” for virtual axes, free encoders and position controllers will be inserted below the PLC device. Note that an update from an existing SoftMotion PLC to a standard PLC is now possible without losing the “General Axis Pool” and the axes configured there. During the update, SoftMotion will be enabled for the standard PLC and the “General Axis Pool” will be preserved.
  • [SM-2819] Issuing a CP movement when the axis group is following the PCS and no movement is active results in error. As long as an axis group follows a dynamic coordinate system, the group state will remain “GroupMoving”. This is in contrast to previous versions, where the axis group would switch to state “GroupStandby” if it was in standstill relative to the moving coordinate system.
  • [SM-2817] SMC_GroupEnableResumeAfterError: there should be an Active output signaling that continue data is being written. If a falling edge of the input SMC_GroupEnableResumeAfterError.Enable is commanded while the continue data is being written (output Active = TRUE), then the continue data will not be valid. A falling edge of Enable can only be safely commanded once the output Active changes to FALSE. This happens once the continue data has been completely written.
Known Limitations
project = “CODESYS SoftMotion” AND fixVersion = 4.9.0.0
project = “CODESYS SoftMotion” AND fixVersion = 4.9.0.0 AND (text ~ COMPATIBILITY_INFORMATION OR text ~ KNOWN_LIMITATIONS)
15.12.2020
Release Note
CODESYS SoftMotion 4.8.0.0 brings important bug fixes and support for more drives.
Major bug-fixes
  • [SM-2501] Kin_Tripod_Rotary, SMC_TRAFO_Tripod_Arm, and SMC_TRAFOF_Tripod_Arm: MCS not documented properly
  • [SM-2584] CP, Halt/Stop: Vel, Acc and JerkFactor are applied twice
  • [SM-2605] MC_Moverelative that finishes in one cycle may output wrong target position
  • [SM-2615] MC_Home: possibly wrong fSetPosition after homing if a 32-bit overflow has occurred
  • [SM-2618] SMC_GroupJog2: Algorithm for finding the working space limits does not work correctly
  • [SM-2631] SMC3_CiA_DSP402_StateMachine: State machine may get stuck if SET_OPMODE times out
12 minor Bugs have been fixed.
Supported drives
  • [SM-2633] New driver for Delta remote IO - R1-EC5621
  • [SM-2417] New driver for Beckhoff EL7041 and EL7047
General
The use of the operator __CHECKLICENSEBIT() (necessary for SM-2571) made it necessary to require at least version 3.5.11.0 of CODESYS. As a consequence, the minimum supported CODESYS version has been increased from 3.5.9.50 to 3.5.11.0.
Known Limitations
Not released / Not tested
  • Device Application Support. The usage of axis groups in child applications is not supported. See SM-847. Not released
10.08.2020
Release Note
CODESYS SoftMotion 4.7.0.0 brings buffer modes to the single axis and master slave function blocks. Additionally, many bugs have been fixed.
New Features
  • [SM-2068] BufferMode for Part 1 function blocks
  • [SM-2333] Robotics: new polar kinematics with z-axis
Major bug-fixes
Only bugs not patched in version 4.6.2.0 or 4.6.3.0 are listed.
  • [SM-2364] Exception when fEditorSlaveMin is set for “0” (CAM_TABLE_INVALID_SLAVE_MINMAX)
  • [SM-2418] Atomic_SRSW_W: Read method returns inconsistent values
  • [SM-2457] CPTR: Assertion in SMC_MotionKernel_CPTR.GetPose after MC_GroupInterrupt
  • [SM-2513] MC_CamIn: Potential AccessViolation if more than three tappets are used in parallel
  • [SM-2515] MC_MoveSuperimposed: jump in axis position if the underlying movement changes the owner and the aborting FB is called before MC_MoveSuperimposed
  • [SM-2521] SML_Drive_ETC: readSDO/writeSDO function block needs to be called with xExecute=FALSE after successful completion
  • [SM-2524] CNC: Interpreter stack overflow if subprogram uses local variables
  • [SM-2530] SMC_MoveContinuousAbsolute/Relative may reach end velocity at wrong position (ramp type trapez, acceleration <> deceleration)
  • [SM-2531] MC_MoveAbsolute / MC_MoveRelative + MC_MoveSuperimposed: possible jump in set position if superimposed movement finished one cycle before underlying movement
33 minor Bugs have been fixed.
Supported drives
  • [SM-2234] New driver for Delta ASDA A3 / B3 drive
General
This version is compatible with CODESYS V3.5 SP9 Patch 5 and newer. However we recommend the newest patch level of CODESYS V3.5 SP15. Using axis groups in simulation-mode requires compiler version 3.5.10.40 or later.
  • [SM-2364] Exception when fEditorSlaveMin is set for “0” (CAM_TABLE_INVALID_SLAVE_MINMAX). MC_CamTableSelect now fails with ErrorID
    • SMC_CAM_TABLE_INVALID_MASTER_MINMAX, if in the passed CamTable fEditorMasterMax <= fEditorMasterMin or fTableMasterMax <= fTableMasterMin.
    • SMC_CAM_TABLE_INVALID_SLAVE_MINMAX, if in the passed CamTable fEditorSlaveMax <= fEditorSlaveMin or fTableSlaveMax <= fTableSlaveMin.
  • [SM-2422] Compatibility: changes in project if the SM package is increased to 4.6.1.0. Logging in to an application downloaded with SoftMotion 4.6.1.0 installed may require an online change when logging in with SoftMotion 4.7.0.0.
Known Limitations
  • [SM-2314] MC_GroupStop/MC_GroupHalt, CP: immediate braking with given dynamic limits. MC_GroupHalt of CP movements cannot be aborted. A subsequent movement is always treated as buffered.
  • Device Application Support. The usage of axis groups in child applications is not supported. See SM-847. Not released.
28.05.2020
Release Note
CODESYS SoftMotion 4.6.3.0 is a bug-fix release. It fixes a major bug in the SMC_GroupJog2 function block.
  • [SM-2480] SMC_GroupJog2: Jogging with ABC_as_ACS does not work correctly
  • [SM-2479] SMC_GroupJog2: possible error “SMC_CP_INVALID_PATH_ELEM” if orientation mode Axis is used
General
Known Limitations
16.03.2020
Release Note
CODESYS SoftMotion 4.6.2.0 is a bug-fix release.
  • [SM-2429] Compatibility: changes in project if the SM package is increased to 4.6.1.0
  • [SM-2430] Axis limit violation on Pick&Place without stop
  • [SM-2431] Problems with CartBlending elements with vanishing axis derivatives: performance degradation and numerical difficulties
  • [SM-2438] MC_GroupInterrupt, CP: Interrupt might not finish if commanded just before the end of a segment
  • [SM-2440] Possible error SMC_CP_INTERNAL_EVAL_CACHE_ERROR on override
  • [SM-2442] Acceleration Limit violation during blending (U-Pick)
General
  • [SM-2429] Compatibility: changes in project if the SM package is increased to 4.6.1.0. Logging into an application downloaded with SoftMotion 4.6.1.0 installed may require an online change when logging in with SoftMotion 4.6.2.0.
Known Limitations
24.02.2020
Release Note
CODESYS SoftMotion 4.6.1.0 is a feature and bug-fix release.
Major bug-fixes
  • [SM-2015] Project environment: Update of SoftMotion profile without installed device description leads to missing SoftMotion libraries
  • [SM-2260] CP, Resume after error: Null reference exception if resume after error is enabled and an error occurs before any movement was planned
  • [SM-2288] AXIS_REF_SM3: Axis generates an error when setting no control mode while moving
  • [SM-2315] Parker PSD: Change the device IDs to fit the previous versions
  • [SM-2340] CNC: The H points are lost for G Codes of Length 0 and if the End Velocity of the previous GCode is 0
  • [SM-2350, SM-2355] Check of Axis Limits fails when a PTP_PI aborts a PTP_FAST mvt and if the IpoState is end_of_path and fIpoTime is 0
36 minor bugs have been fixed.
New Features
  • [SM-1304] Robotics: Support for 6D tools
  • [SM-2247] Robotics: make it possible to resume after MC_GroupHalt/MC_GroupStop
  • [SM-2152] Improve CP-Tracking for Pick&Place applications step 1
Improvements
  • [SM-2183] AXIS_REF_MAPPING_SM3: new setting to enable writing of outputs in application stop
  • [SM-2192] SMC_GroupJog2: handle huge distances better
  • [SM-2222] Robotics: Improve CP kernel on multicore
  • [SM-2269] Orientation mode axis: don’t create an error if orientation mode axis is used on a kinematics without any orientation DOF
  • [SM-2299] Support mapping of I/O Parameters of type BIT
Supported drives
  • [SM-638, SM-1191, SM-2305] Driver for Beckhoff EL7031 stepper module
  • [SM-2229] Yaskawa: Integrate Sigma-7 400V double axis
  • [SM-2215] SM3_Drive_ETC_KEB_H6: make it possible to immediately disable from state quick stop, even if _bImmediateDisabling is FALSE
  • [SM-2233] SM3_Drive_ETC_KEB_H6: consider voltage enabled, ignore operation enabled
  • [SM-2273] Festo CMMP-AS - remove startparameter sw limits
General
Issues from version 4.6.1.0
  • [SM-2314] MC_GroupStop/MC_GroupHalt, CP: immediate braking with given dynamic limits. MC_GroupStop/MC_GroupHalt now require the commanded dynamics to be valid. This means that the values of the inputs Deceleration and Jerk have to be positive and the values of the inputs AccFactor and JerkFactor have to be in the range ]0, 1]. An invalid value on any of these inputs leads to an error stop. If you update an application to this SoftMotion version, please make sure that all calls to MC_GroupStop/MC_GroupHalt in your application have valid inputs.
Issues from version 4.6.0.0
  • [SM-2067] Infranor Xtrapuls: it is not possible to access the high 16 bit of the digital inputs and digital outputs Infranor Xtrapuls: The member variables wDigitalInputs and wDigitalOutputs of the SoftMotion axes are now of type DWORD instead of WORD. Updating these devices in existing projects can lead to new compile errors, if wDigitalInputs or wDigitalOutputs were assigned to WORD variables.
  • [SM-2080] U-Pick: improve smoothness to reach more picks per minute: Blending between path elements has been improved to enable faster and smoother pick&place operation. In particular, consecutive lines are now blended even if their direction is exactly opposite to each other (e.g. the down-movement followed by the up-movement of a typical pick&place cycle). To restore the behavior of SoftMotion versions before 4.6.0.0, set the flag bCPCompositeBlending of the structure SMC_AXIS_GROUP_COMPATIBILITY_OPTIONS to FALSE (input of MC_GroupEnable). Note: this change only affects non-tracking movements.
  • [SM-2191] Robotics: change default planning interval to 16 ms: The default for the robotics planning interval has been changed to 16 ms. The planning interval is an internal parameter of the robotics trajectory planner. The value determines the accuracy of the trajectory and the performance requirements of the planning algorithm. (Larger planning intervals lead to reduced performance requirements.) In earlier versions of CODESYS SoftMotion, the default for the planning interval was twice the bus task interval, but at least 4 ms. The planning interval can be changed using SMC_TuneCPKernel.
Known Limitations
20.01.2020
Release Note
CODESYS SoftMotion 4.6.0.0 is a feature and bug-fix release.
Major bug-fixes
  • [SM-2116] SM: AutoMoveGantry: axis limit violation
  • [SM-2146] AxisGroup: Enable AxisGroup implicit code creation
24 minor bugs have been fixed.
Improvements
  • [SM-106] SM: AXIS_REF_ETC: make it possible to access the EtherCAT slave
  • [SM-644, SM-1236] SM_Drive_PosControl: it should be possible to adjust the parameters online by the iec application
  • [SM-1973] When controller mode “nocontrol” is set, the SoftMotion driver will not write the cyclic outputs of the drive
  • [SM-2016] Robotics: allow to resume the programmed path after an error
  • [SM-2190] Scaling: new scaling view for linear motors
  • [SM-2097] Robotics: improve blending if tangent and curvature matches
  • [SM-2211] Brake Control FB: Create a new Parameter to get the brake state
Supported drives
  • [SM-1967] CMZ LBD
  • [SM-2119] Updated driver for Panasonic MINAS A5B and MINAS A6B
  • [SM-2166] Updated driver for new firmware of Parker PSD
General
Known Limitations
09.09.2019
