CODESYS SoftMotion Axes (256)
With this license, up to 256 real axes, and additionally 256 virtual axes, can be controlled.
Functional principle
Engineering of motion control using function blocks
Configuration of drives based on the fieldbus support integrated in the CODESYS Development System
Separation of application development from drive configuration. The drives in the device tree are accessed symbolically (by name) from the application. Changes in the drive configuration are possible without changing the application.
Typical applications
As an additional option for powerful, CODESYS compatible control systems with good real-time behavior (FPU recommended)
Actuation of single-axis and multi-axis movements, for example with position and velocity definitions, drive functions, and phase actuation
Implementation of electronic cams
All supported by CODESYS:
Real-time capable operating system platforms
CPU platforms with available FPU (Floating Point Unit)
Devices with integrated fieldbus (EtherCAT, CAN/CANopen)
WIBU Codemeter Support
