Search results for: 'into price'
- into control 106
- price class 40
- into to codesys 131
- price apache 34
- into plc 124
CODESYS Sensor App for Android 000073$0.00With the product “CODESYS Sensor App for Android”, the sensor data of from an Android smartphone can be sent to a CODESYS controller.
HVAC Modbus SL 2312000013$0.00HVAC Modbus Library. Send and receive Modbus data points via RTU (serial) or TCP. Finished function blocks many manufacturers and devices from building automation. Further description: https://support.powerio.com/codesys-hvac/hvac-modbus-library/description
HVAC I/O Modbus Modules 2312000001$0.00The library allows the use of HVAC Modbus I/O modules of the manufacturer powerIO via a RS485 COM port. The devices are appended in the project tree and are parameterized from there without further programming effort. In the I/O Mapping area the assignments of the input/output variables can be set. The modules are available with emergency manual operation level and without. The status of the manual override is queried.
