Search results for: 'add ons'
- add+of 116
- add of 116
- add and 106
- ONS in codesys 94
- additional license 85
CODESYS V3 Intensive Training - Orlando, FL - Apr 2026 2108100012-T-2026-04-20$2,750.00Available: 9 of 16Apr 20, 2026 (08:00 EDT) - Apr 23, 2026 (15:00 EDT)
Orlando, FLThis 30-hour training is targeted for experienced control engineers transitioning to CODESYS, or for engineers wishing to take their knowledge of CODESYS to the next level. It combines basic and advanced training modules to give participants a comprehensive understanding of the capabilities of CODESYS, alternating between lectures and hands-on labs. It includes hints, tricks, and best practices compiled from many years of experience.
CODESYS V3 Essentials Training - LIVE ONLINE - May 2026 2108100015-T-2026-5-11$1,500.00Available: 15 of 20May 11, 2026 (11:00 EDT) - May 14, 2026 (16:00 EDT)
